986|4
682
108
【国产FPGA高云GW1N-4系列开发板测评】——6、数码管显示时钟(时、分、秒) [复制链接]
   从开发板原理图可看出,4位7段数码管为共阳极类型。位选信号LED_DIS_SEL为低电平‘0’时,驱动三极管导通,数码管供电;数码管段码由低电平驱动,为低电平的段被点亮。
   原理图中对应FPGA管脚分配如下图所示
   在用户手册中也有管脚分配相关信息。
   用LED数码管数据生成器生成0到9的共阳显示码。
   实现代码如下:
--*-------------------------- file ---------------
--* name:  segx4.vhd
--* ver : A
--* date:2021-12-9
---------- LIB  ----------------------------------------------------------------
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
----------ENTITY -------------------------------------------------------------
ENTITY segx4 IS
PORT (
--系统全局时钟 CLK
    CLK_50M:    IN  STD_LOGIC;	--50MHz系统时钟
--系统全局复位 RESET
    NRESET:     IN  STD_LOGIC;
--SEGx4
    DIS:        OUT  STD_LOGIC_VECTOR(7 DOWNTO 0);
    SEL:        OUT  STD_LOGIC_VECTOR(4 DOWNTO 1);
--SWx4
    SW:         IN  STD_LOGIC_VECTOR(4 DOWNTO 1)
END segx4;
-----------ARCHITECTURE-------------------------------------------------------
ARCHITECTURE MY_CODE OF segx4 IS
    SIGNAL	 COUNTER:       integer range 0 to 50000000;
    SIGNAL	 LED_Reg:       STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL	 COUNTER1:      integer range 0 to 62500;
    SIGNAL	 CNT:           integer range 0 to 8;
    SIGNAL   SCAN_CLK:       STD_LOGIC;
    TYPE DIS_Reg_Index IS ARRAY(1 to 4) OF STD_LOGIC_VECTOR(7 downto 0);
    SIGNAL   DIS_Reg:   DIS_Reg_Index;
    SIGNAL	 SEL_Reg:       STD_LOGIC_VECTOR(4 downto 1);
    TYPE SMG_INDEX IS ARRAY(0 to 9) OF STD_LOGIC_VECTOR(7 downto 0);
    CONSTANT SMG:       SMG_INDEX := (  X"C0",  -- 0
                                        X"F9",  -- 1
                                        X"A4",  -- 2
                                        X"B0",  -- 3
                                        X"99",  -- 4
                                        X"92",  -- 5
                                        X"82",  -- 6
                                        X"F8",  -- 7
                                        X"80",  -- 8
                                        X"90"   -- 9
    CONSTANT BLANK:     STD_LOGIC_VECTOR(7 DOWNTO 0):=X"FF";
    SIGNAL   TICK_CLK:     STD_LOGIC;
    SIGNAL   HR:        integer range 0 to 23;
    SIGNAL   MIN:       integer range 0 to 59;
    SIGNAL   SEC:       integer range 0 to 59;
BEGIN
PROCESS(NRESET,CLK_50M)
BEGIN
	IF (NRESET = '0') THEN
        COUNTER <= 0;
	ELSIF (RISING_EDGE(CLK_50M)) THEN
        IF (COUNTER < 50000000-1) THEN
            COUNTER <= COUNTER + 1;
        ELSE
            COUNTER <= 0;
        END IF;
	END IF;
END PROCESS;
BEGIN
        COUNTER1 <= 0;
        IF (COUNTER1 < 62500-1) THEN
            COUNTER1 <= COUNTER1 + 1;
        ELSE
            COUNTER1 <= 0;
        END IF;
	END IF;
END PROCESS;
BEGIN
        SCAN_CLK <= '0';
        IF (COUNTER1 = 62500-1) THEN
            SCAN_CLK <= NOT SCAN_CLK;
        END IF;
	END IF;
END PROCESS;
PROCESS(NRESET,SCAN_CLK)
BEGIN
        CNT <= 1;
	ELSIF (RISING_EDGE(SCAN_CLK)) THEN
        IF (CNT = 4) THEN
            CNT <= 1;
        ELSE
            CNT <= CNT + 1;
        END IF;
	END IF;
END PROCESS;
    SEL_Reg <=  (1=>'0',others=>'1') WHEN CNT = 1 ELSE
                (2=>'0',others=>'1') WHEN CNT = 2 ELSE
                (3=>'0',others=>'1') WHEN CNT = 3 ELSE
                (4=>'0',others=>'1') WHEN CNT = 4 ELSE
                (others=>'1');
    SEL <= SEL_Reg;
    DIS         <=  DIS_Reg(CNT);
    DIS_Reg(4)  <=  SMG(MIN / 10)   WHEN SW(1)='0' ELSE
                    BLANK           WHEN SW(1)='1' AND (HR/10)=0 ELSE
                    SMG(HR / 10);
    DIS_Reg(3)  <=  (NOT TICK_CLK) & SMG(MIN REM 10)(6 downto 0) WHEN SW(1)='0'  ELSE
                    '0' & SMG(HR REM 10)(6 downto 0);
    DIS_Reg(2)  <=  SMG(SEC / 10)   WHEN SW(1)='0'  ELSE
                    SMG(MIN / 10);
    DIS_Reg(1)  <=  SMG(SEC REM 10) WHEN SW(1)='0'  ELSE
                    SMG(MIN REM 10);
BEGIN
        TICK_CLK <= '0';
        IF (COUNTER = 25000000-1) OR (COUNTER = 50000000-1)THEN
            TICK_CLK <= NOT TICK_CLK;
        END IF;
	END IF;
END PROCESS;
PROCESS(NRESET,TICK_CLK)
BEGIN
        HR  <= 23;
        MIN <= 59;
        SEC <= 00;
	ELSIF (RISING_EDGE(TICK_CLK)) THEN
        IF (SEC = 59) THEN
            SEC <= 0;
            IF (MIN = 59) THEN
                MIN <= 0;
                IF (HR = 23) THEN
                    HR <= 0;
                ELSE
                    HR <= HR + 1;
                END IF;
            ELSE
                MIN <= MIN + 1;
            END IF;
        ELSE
            SEC <= SEC + 1;
        END IF;
	END IF;
END PROCESS;
END MY_CODE;
   VHDL比Verilog用起来稍麻烦一些,VHDL比较严谨,数据类型不同会报错,需要转换后才可赋值;语法要求也比较严格。
   10到13行为公共库声明,没有库简单的代码编译都做不到。15到41行实体定义,定义输入输出接口。
   45到76行,定义变量和常量,在使用前必须定义,定义必须在整个代码实现BEGIN(80行)之前。
   82到93行,分频产生1Hz节拍时钟;
   95到106行,分频产生800Hz数码管扫描基准时钟。50,000,000 / 62,500 = 800;
   108到117,800Hz翻转时钟,实际对应数码管扫描时钟400Hz。
   119到130行,数码管扫描计数器,1到4循环;
   132到138行,CNT从1到4循环,分别对应数码管位1到4。
   通过一位拨码开关SW(1)来选择功能。当SW(1)为'0'时,功能为4位数据码显示分、秒,并伴随有“点段”闪烁;当当SW(1)为'1'时,功能为显示时、分,点段常亮,当时位小于10时,只显示一位,大于等于10时显示2位。SEL的位选、DIS的显示段值正好都与CNT相关,每个位显示寄存器DIS_REG()实时赋值,DIS_Reg(CNT)查表显示。
   151到160行,产生1Hz节后时钟。
   162到185行,产生24小时时钟的时、分、秒,方法也比较简单易懂。在秒时钟的节拍下秒、分都是59进位,时为23归零。
   时间初值设置为23点59分00秒,是为了区分从23点跳到0点后,只显示一位小时。
   视频上传不成功。
   视频截取了gif图片,显示比较快,实际为秒闪。拨码开关打到下方时,显示分、秒,分个位的点闪烁;拨到上方时,显示时、分,时的个位点常亮。
682
108
工程文件:
segx4_shizhong.rar (64.79 KB, 下载次数: 0)
大佬使用VHDL,厉害  详情 回复 发表于 2021-12-26 17:20
88
大佬使用VHDL,厉害
不厉害,一般般,用VHDL只是个人习惯问题。Verilog可以加头文件,可以'define,这点比VHDL人性化。有时也混用,模块化设计,不同语言写的模块可以相互调用。 语言只是个工具,FPGA的硬件思维是灵魂。  详情 回复 发表于 2021-12-26 17:37
682
108
我是刚入门的小白,就觉得Verilog,简单,好上手,懂C语言的,简直是无门槛入门。VHDL,做复杂系统稳定。  详情 回复 发表于 2021-12-26 22:20
88
gs001588 发表于 2021-12-26 17:37 不厉害,一般般,用VHDL只是个人习惯问题。Verilog可以加头文件,可以'define,这点比VHDL人性化。有 ...
