1、简介
前面我们介绍了通过GPIO引脚和PWM结合DMA这两种方式来实现对WS2812B的驱动,本篇帖子我们就来介绍另外一种方式:通过MCU的SPI接口来驱动WS2812B,我们通过配置SPI的8个时钟周期满足WS2812B所需要的1位所占用的时间,通过发送的数据来控制WS2812B一位当中的高低电平占比来实现;通过SPI接口,我们仅需使用到MOSI一个引脚即可,下面我们来看看程序是如何配置和实现的。
2、主要程序代码
#define WS2812B_SPI_BIT_H 0xF8
#define WS2812B_SPI_BIT_L 0xC0
* @brief * @param
* @retval
* @attention *******************************************************************************/
static void WS2812B_Write24Bits(uint8_t R, uint8_t G, uint8_t B)
for(uint8_t i = 0; i < 8; i++)
if((G << i) & 0x80)
RGB_BitBuffer[i + 0x00] = WS2812B_SPI_BIT_H;
else
RGB_BitBuffer[i + 0x00] = WS2812B_SPI_BIT_L;
if((R << i) & 0x80)
RGB_BitBuffer[i + 0x08] = WS2812B_SPI_BIT_H;
else
RGB_BitBuffer[i + 0x08] = WS2812B_SPI_BIT_L;
if((B << i) & 0x80)
RGB_BitBuffer[i + 0x10] = WS2812B_SPI_BIT_H;
else
RGB_BitBuffer[i + 0x10] = WS2812B_SPI_BIT_L;
__disable_irq();
for(uint8_t i = 0; i < 24; i++)
while(!(SPI_STAT(SPI1) & SPI_FLAG_TBE));
SPI_DATA(SPI1) = RGB_BitBuffer;
__enable_irq();
* @brief
* @param
* @retval
* @attention
static void WS2812B_DisplayFullColor(void)
static uint8_t Index = 0;
static uint8_t Count = 0, Mode = 0;
uint8_t R_TAB[65] =
255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 240, 220,
200, 180, 160, 140, 120, 100, 80, 60, 40, 20, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 20, 40, 60, 80, 100, 120, 140,
160, 180, 200, 220, 240
uint8_t G_TAB[65] =
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 20, 40, 60,
80, 100, 120, 140, 160, 180, 200, 220, 240, 255, 255, 255, 255, 255, 255,
255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
uint8_t B_TAB[65] =
0, 20, 40, 60, 80, 100, 120, 140, 160, 180, 200, 220, 240, 255, 255,
255, 255, 255, 255, 255, 255, 255, 255, 255, 240, 220, 200, 180, 160, 140,
120, 100, 80, 60, 40, 20, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0
uint8_t Step = 31, CountCOMP = 30;
switch(Mode)
case 0: RGB_Gradient(0x00,0x00,0x00, 0x00,0x00,0xFF, Step); break;
case 1: RGB_Gradient(0x00,0x00,0x00, 0x00,0xFF,0x00, Step); break;
case 2: RGB_Gradient(0x00,0x00,0x00, 0xFF,0x00,0x00, Step); break;
default: break;
for(uint8_t i = 0; i < 60; i++)
if(Mode != 3)
WS2812B_Write24Bits(RGB_TAB[Index][0], RGB_TAB[Index][1], RGB_TAB[Index][2]);
Index = (Index + 1) % Step; CountCOMP = 30;
else
WS2812B_Write24Bits(R_TAB[Index], G_TAB[Index], B_TAB[Index]);
Index = (Index + 1) % 65; CountCOMP = 60;
if(Count++ == CountCOMP)
Count = 0;
Index = 0;
Mode = (Mode + 1) % 4;
* @brief
* @param
* @retval
* @attention
void WS2812B_Init(void)
spi_parameter_struct spi_init_struct;
rcu_periph_clock_enable(RCU_GPIOB);
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
gpio_af_set(GPIOB, GPIO_AF_6, GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15);
rcu_periph_clock_enable(RCU_SPI1);
spi_i2s_deinit(SPI1);
spi_struct_para_init(&spi_init_struct);
spi_init_struct.trans_mode = SPI_TRANSMODE_FULLDUPLEX;
spi_init_struct.device_mode = SPI_MASTER;
spi_init_struct.frame_size = SPI_FRAMESIZE_8BIT;
spi_init_struct.clock_polarity_phase = SPI_CK_PL_HIGH_PH_2EDGE;
spi_init_struct.nss = SPI_NSS_SOFT;
spi_init_struct.prescale = SPI_PSC_4;
spi_init_struct.endian = SPI_ENDIAN_MSB;
spi_init(SPI1, &spi_init_struct);
spi_fifo_access_size_config(SPI1, SPI_BYTE_ACCESS);
spi_enable(SPI1);
WS2812B_DisplayAllRed(); SysTick_DelayMS(500);
WS2812B_DisplayAllGreen(); SysTick_DelayMS(500);
WS2812B_DisplayAllBlue(); SysTick_DelayMS(500);
TASK_Append(TASK_ID_WS2812B, WS2812B_DisplayFullColor, 50);
3、运行视频效果
4、时序控制截图:完美的波形
5、工程源码
Template_SPI.zip
(391.89 KB, 下载次数: 22)
