155|0
2464
0.3uA超低功耗LDO  ZCC7002 [复制链接]
0.3uA Extremely Low Iq, 150mA LDO Regulator with Programmable Output Voltage and Enable
一:Description
The ZCC7002 series are low quiescent current and low dropout regulators with 4-level programmable output voltages. These LDOs are suitable for portable battery powered devices.
A precision bandgap and an error amplifier provide 3% accuracy over line, load and temperature. The extremely life. Furthermore, enable function lowers current consumption when devices are disabled, and an internal switch discharges output capacitor Cout.
The ZCC7002 series of LDO linear regulators also featuies current limiting and shore-circuit protection for safety.
二:Features
·Extremely low Iq of 0.3uA at 3.3V outout
·Low dropout voltage:
Typ 400mV at Iout=150mA,Vout=3.3V
·Programmable 4-level output voltages
·3% accuracy over line, load and temperature
·Enable pin controls output with ultra-low shutdown current of 0.1uA
  When disabled
·Stable with a 1uF ceramic capacitor
·Output load discharge when disabled
·Over current limit and short-circuit protection
三:Applications
Wireless handsets, Smart phones, IoT, Battery-powered equipment, Camcorders, Cameras, Microprocessor rails.
    大量应用于电子秤/玩具/厨房秤/保温杯/智能电表/蓝牙音箱/筋膜枪 4通道/四触摸按键IC
    产品型号:VK3604B/VK3604A 产品品牌:VINKA/永嘉微电/永嘉微 封装形式:TSSOP1 ...
    来看看用这种技术对风机轴维修的实际效果
      风机主轴是传递转矩的部件,是设备的关键部件,所以一旦出现轴磨损的情况,要及时 ...
    MicroPython在ESP32-S3中添加SDCard功能
    在最新的更新中,micropython在ESP32-S3中添加了对SDCard支持 esp32: Add SDCard s ...
    手持电动工具散热成困扰,兆科TIF100导热硅胶片为你解决
    手持式电动工具,指的是便携式的电动工具,可直接用手操作无需其他辅助装置。手持 ...
    起草皮机电机驱动的国产MOS管:170N8F3A可替换IPP037N08N3G的型号参数!
    能为起草皮机电机驱动厂家持续稳定供应性能优质的MOS管,并且其能够匹配IPP037N08N3G ...
    定制铜绞线软连接,多股软铜绞线软连接,多股一体化裸铜绞线软连接批发价格
    铜绞线规格、型号、常用截面积: TJ—20 : TJ—硬态铜绞线 20—截 ...
