110|0
2466
2/3/4节锂电池同步升压充电芯片zcc5518 [复制链接]
2~4节锂电池同步升压充电芯片zcc5518
High Efficiency, 1A, Four-Cell Boost Li-Ion Battery Charger Preliminary Specification
1.General Description
ZCC5518 is a highly integrated synchronous boost charger IC for Lithium-ion batteries with four cells in series. The charge current up to 1A can be programmed by using the external resistor for different portable applications.
Robust protections include input over-voltage protection (OVP), battery OVP, battery short protection, thermal shut down, battery temperature monitor, a configurable timer to prevent prolonged charging of a dead battery.
2. Features
·3.0V to 5.5V Operating Input Voltage
·Up to 26V Sustainable Voltag
·Up to 1A Configurable Charge Current or Battery with 4 Cells in Series
·Configurable Input Voltage Limit
·Charge Status Indication
·Constant Voltage Selectable
·Programmable Charge Timeout
·Thermal Regulation Protection
·External Shutdown Function
·Input Voltage UVLO and OVP
·Over Temperature Protection
·Output Short Circuit Protection Normal Synchronous Boost Operation When Battery Removed
    耐压16V,USB充锂电池+1.5V输出,锂电池替代干电池方案专用芯片1uA低功耗  ZCC5600
    耐压16V,USB充锂电池+1.5V输出,锂电池替代干电池方案专用芯片1uA低功耗 ZCC5600 ...
    矢量网络分析仪的关键技术指标及热门品牌介绍
    矢量网络分析仪是用途极广的一类仪器,它们可以表征 S 参数、匹配复数阻抗、以及进行 ...
    贴片加工厂_静电防护设施
    贴片加工厂的生产车间对于环境是有一定要求的,如电源、无尘、空气、防静电等各个方面 ...
    高功率5G通讯散热,哪款导热材料才更合适呢?
    随着通讯技术行业的不断发展,5G已经大规模的正式商用。从功率上来说,5G的功率是4 ...
    电动充气泵方案介绍
         电动充气泵具有体积小、智能数显、预设胎压、动态测量等功能,颇受出行人员 ...
    蓝牙资讯|蓝牙音频消费报告
    2021年蓝牙音频设备看法 2021 年与 2020 年真无线耳塞的使用情况 ...
