25|0
52
台湾德律TRI 5001 ICT+FCT在线組裝电路板测试机 [复制链接]
新一代的在线型ICT+FCT解决方案拥有突破性的优越表现,多核心平行测试功能具多达四个独立的核心,能够大幅提升测试产能。可相容SMEMA的在线型处理器,降低了操作员的工作量并且提升了工作效能,并且具有长生命周期的快速插拔治具,结合内建自我诊断系统及支援自动校验功能,能够确保长期的测试可靠度。
• 新一代高弹性多核心平行测试
• 先進串列测试功能多达8个独立的连接埠可量测任一脚位
• 有限接入解决方案,并使用PXI模组功能测试扩张
• 内建自我诊断系统及支援自动校验功能
• 高精准度量测与测试
• 相容SMEMA在线檢出率率高的测试解决方案
• 直觉化與流程化简易编程使用介面
Tester Specifications
Analog/hybrid test points TR5001Q(L) SII INLINE: 4096
TR5001D(L) SII INLINE: 3328
TR5001(L) SII INLINE: 3456
Operating System Microsoft® Windows compatible PC with USB, Windows 10
Fixture Type Inline with long lifespan Quick Disconnection Interface
Standard Testing Components
Analog Test Hardware
  • 6-wire measurement switching matrix
  • Programmable AC/DC/DC High voltage and current sources
  • AC/DC voltage, DC current measurement
  • Component R/L/C measurement
Optional Components
Analog Hardware
  • TestJet vectorless open circuit detection
  • Arbitrary Waveform Generator
Digital Testing
  • Non-multiplexing 1:1 per pin architecture with independent per-pin level setting
  • DUT power supplies: 5 V@3 A, 3.3 V@3 A, 12 V@3A, -12 V@1 A and 24 V@3 A
  • Programmable DUT power supplies: 75 V / 8 A max, 200W maximum output power
  • Includes BScan Chain Test, BScan Cluster Test, BScan Virtual Nails Test, BScan Virtual Chain Test and IEEE1149.6 Test
  • Up to 8 High Speed Serial Ports, On-board Flash, EEPROM, MAC programming
Yield Management System YMS 4.0
Board Handling
Min. PCB Size 70 x 70 mm
Max. PCB Size TR5001(D/Q) SII INLINE:500 x 360 mm
TR5001(D/Q)L SII INLINE: 510 x 510 mm
PCB Thickness 0.6 - 5 mm
Dimensions
WxDxH
TR5001(D/Q) SII INLINE: 900 x 1080 x 1660 mm
TR5001(D/Q)L SII INLINE: 1000 x 1230 x1676 mm
Note: not including signal tower,signal tower height: 390 mm
Weight
TR5001(D/Q) SII INLINE: 670 kg
TR5001(D/Q)L SII INLINE: 720 kg
软件版本:5001
软件下载:https://pan.baidu.com/s/1oGg-SUUQ0F38HNHa5juoZQ 提取码:mq8o
备用下载:https://pan.baidu.com/s/1JFkEUpSAKOMk6ZJS7PD6JA 提取码: 89ft
