38|0
2210
28V 线性充电 ZCC3221替代CE3221 [复制链接]
INTRODUCTION :
The ZCC3221 is a complete constant-current/ constant-voltage linear charger for single cell lithium rechargeable battery. No external sense resistor is needed, and no blocking diode is required due to the internal P-MOSFET architecture. Furthermore, the ZCC3221 is specifically designed to work with in USB power specifications. Its low external component count makes the ZCC3221 ideally suited for portable applications. Thermal feedback regulates the charge current to limit their temperature during high power operation or high ambient temperature. The charge current can be programmed externally with a single resistor. The ZCC3221 automatically terminates the charge cycle when the charge current drops to 1/10ththe programmed value after the final float voltage is reached. When the input supply (wall adapter or USB supply) is removed, the ZCC3221 automatically enters a low power sleep mode, dropping the battery drain current to less than 2mA.The ZCC3221 can be put into shutdown mode, reducing the supply current to 50mA.Other features include battery pack temperature monitor, under voltage lockout, automatic recharge and two status pins to indicate charging and charge termination.
  1. Charges Single Cell Lithium Battery Directly from USB Port or ACAdapter
  2. Input VoltageRangeFrom    4.5V to24V
  3. InputOVP:6.5V
  4. No External MOSFET, Sense Resistor or Blocking DiodeRequired
  5. Preset4.20V/4.35VChargeVoltage
  6. Continuous Programmable Charge Current Up to1.2A
  7. Recharge Conditioning for Reviving Deeply Discharged Cells   and Minimizing  Heat Dissipation during Initial Stage ofCharge
  8. Constant-Current/Constant- Voltage/Constant-Temp Operation   with ThermalRegulationtoMaximizeChargeRate Without Risk ofOverheating
  9. Battery ReverseProtection
  10. AutomaticRecharge
  11. Battery TemperatureSensing
  12. Charge state pairs of output, no battery and fault statusdisplay
  13. Charge Current Monitor Output for Gas Gauging
  14. Automatic Low Power Sleep Mode When Input Supply Voltage isRemoved
  15. Soft-Start Limits InrushCurrent
  16. Chip Enable Input
