41|0
438
零失业率并不是一件好事 [复制链接]
While on the surface it appears that a 0% unemployment rate would be terrific for the citizens of a country, having a small amount of unemployment is actually desirable.
从表面上看,零失业率对一个国家的公民来说应该是好到爆了,然而实际上保留一个小幅的失业率才是好事。
To understand why we need to look at the three types (or causes) of unemployment.
要弄明白为什么,我们首先得来看看失业的三种形式。(或者说三种成因)
Cyclical Unemployment is defined as occurring "when the unemployment rate moves in the opposite direction as the GDP growth rate. So when GDP growth is small (or negative) unemployment is high." When the economy goes into recession and workers are laid off, we have cyclical unemployment.
周期性失业的定义是:失业率与GDP的增速呈负相关的关系。也就是说,当GDP增长率很小(或者为负)的时候,失业率会很高。当一个经济体进入衰退期,工人开始失业的时候,我们就遭遇了周期性失业。
Cyclical unemployment occurs when an economy's output deviates from potential GDP- i.e. the long-term trend level of output in an economy.
当一个经济体的产出偏离潜在GDP的时候,也就是偏离长期的产出趋势的时候,周期性失业就出现了。
When an economy's output is higher than the level of potential GDP, resources are utilized at levels higher than normal and cyclical unemployment is negative.
而当经济体的产出比潜在GDP更高的时候,资源的利用率会比正常情况下更高,这时周期性失业率就会为负。
Conversely, when an economy's output is lower than the level of potential GDP, resources are utilized at levels lower than normal and cyclical unemployment is positive.
反过来,如果经济体的产出低于潜在GDP,资源的利用效率就会低于正常值,那周期性失业率就会为正。
Put simply, cyclical unemployment is unemployment associated with business cycles- i.e. recessions and booms.
简单地讲,周期性失业是和经济周期有关的失业,也就是衰退期和繁荣期。
Frictional Unemployment: We define frictional unemployment as "unemployment that comes from people moving between jobs, careers, and locations."
摩擦性失业:我们对摩擦性失业的定义是“当人们切换工作、行业或工作地点时发生的失业”。
If a person quits his job as an economics researcher to try and find a job in the music industry, we would consider this to be frictional unemployment.
如果一个人辞掉了经济学研究员的工作,转而去音乐行业找工作,就属于我们所说的摩擦性失业。
Frictional unemployment is unemployment that comes from people moving between jobs, careers, and locations- in other words, unemployment that arises because most people don't enter into a new job immediately after exiting an old one (voluntarily or involuntarily).
摩擦性失业会在人们切换工作、切换行业、切换工作地点的时候发生,换句话说,它的出现是因为人们辞掉旧工作之后并不能立刻开始一个新工作。(不管是自愿的还是非自愿的)
Frictional unemployment is not thought to be a big problem from a policy standpoint because it is entirely reasonable that people would take some time to find a job that is a good match rather than take the first opportunity that comes along.
从政策的角度来讲,摩擦性失业并不是一个大问题,因为它的成因完全可以理解,人们肯定更倾向于花点时间找个真正适合自己的工作,而不是单纯接受眼前的第一个机会。
Technology that helps to match workers with jobs and streamline the interview and hiring process most likely result in the amount of frictional unemployment that exists in an economy.
那些帮助求职者匹配新工作的技术,以及帮助他们优化面试和招聘流程的技术,很可能导致了一个经济体中摩擦性失业率的升高。
Structural Unemployment: We define structural unemployment as "unemployment that comes from there being an absence of demand for the workers that are available".
结构性失业:我们对结构性失业的定义是“当劳动力需求相较于现有求职者人数而言出现缺口时产生的失业。”
Structural unemployment is often due to technological change.
结构性失业通常来源于技术变革。
If the introduction of DVD players cause the sales of VCRs to plummet, many of the people who manufacture VCRs will suddenly be out of work.
如果DVD机的出现让VCR的销量暴跌,那么很多生产VCR的人就会突然失去工作。
By looking at these three types of unemployment, we can see why having some unemployment is a good thing.
看了这3种失业形式之后,我们就能明白为什么适当的失业率是好的了。
Most people would argue that since cyclical unemployment is the by-product of a weak economy, it is necessarily a bad thing, though some have argued that recessions are good for the economy.
很多人可能会说:由于周期性失业是经济疲软的副产品,所以它肯定是个坏事,虽然也有人说衰退对一个经济体来说有好处。
What about frictional unemployment? Let's go back to our friend who quit his job as an economic research to pursue his dreams in the music industry.
那摩擦性失业呢?我们再来看看刚刚那位辞掉经济学研究员工作转而投身音乐界的朋友。
He quit a job he disliked to attempt a career at the music industry, even though it caused him to be unemployed for a short while.
他辞掉了一份自己不喜欢的工作,转而寻求一份音乐界的工作,即使短暂失业也在所不惜。
Or consider the case of a person who is tired of living in Flint and decides to make it big in Hollywood and who arrives in Tinseltown without a job.
或者我们来想象一个厌倦了在小城弗林特生活的人,他决定去好莱坞寻求飞黄腾达的机会,于是以失业状态来到了浮华城。
A great deal of frictional unemployment comes from people following their hearts and their dreams.
很大一部分摩擦性失业都是源于人们追寻自己的性子和梦想。
This is certainly a positive type of unemployment, though we would hope for these individuals' sakes that they do not stay unemployed for too long.
这当然是一种积极型的失业,不过我们希望这些人不要失业太久。
Finally, structural unemployment. When the car became commonplace, it cost a lot of buggy manufacturers their jobs. At the same time, most would argue that the automobile, on net, was a positive development.
最后,结构性失业。当汽车成为常态的时候,很多马车制造业的人失去了工作。而同时,大多数人会觉得自动化汽车从总体上来讲是个积极的发展方向。
The only way we could ever eliminate all structural unemployment is by eliminating all technological advancement.
要消除所有的结构性失业,我们只能消除所有的技术进步。
By breaking down the three types of unemployment into cyclical unemployment, frictional unemployment, and structural unemployment, we see that an unemployment rate of 0% is not a positive thing.
在把失业拆分成周期性失业、摩擦性失业和结构性失业之后,我们可以看出来,零失业率并不是一件好事。
A positive rate of unemployment is the price we pay for technological development and for people chasing their dreams.
一点正向的失业,是我们为技术进步与逐梦自由付出的代价。
大连华工创新科技股份有限公司拥有全球领先技术、十年品质保证、贴心的售前售后服务,优秀的研发团队,保证客户不同的需求。有意者请登录www.hgcx.cn或致电0411-39525022密封点胶机,胶条发泡机,聚氨酯涂胶机,机柜密封打胶机,双组份淋胶机,板材刷胶机,断桥铝门窗注胶机 涂胶机 密封点胶机 机柜密封 机器人涂胶机 胶条发泡机 断桥铝注胶机 穿条发泡 板材刷胶机 汽车涂胶机 全自动点胶机 PU发泡机 密封胶条设备 自动密封 电表箱防水密封
Website: HGIT Dispensing system dispensing machine for Cabinets CNC PU Seal Pouring Machine Foam sealing gasket machine Injection (Potting) Machine barrier-strip foam technique Customized production solutions Foam sealing machine (FIPFG) Warm Edge Spacer Forming Machine PU foam dispensing machine Glue Dispensing Robot strip feeding PU foam Foam in Place Gasket machine
涂胶机,密封点胶机,注胶机<
