50|0
1232
ARCH工业用模块电源AIC [复制链接]
ARCH是台湾著名的电源模块电源制造商。ARCH主要提供大功率AC-DCDC-DC电源模块,这些模块电源经常使用于系统前端。目前,ARCH的电源模块用户涵盖显示器、仪器仪表设备、医疗设备、机械自动化、医疗、城市轨道交通等各个领域,ARCH的电源模块具备大功率、小体积的特点
ARCH工业模块电源模块AIC是一种安装在PCB上的开关电源模块。模块电源具备完全密封性的塑料外壳和低纹波和噪音,通用性输入范围为90-264VAC47-63Hz,超紧凑型规格尺寸为1.41x0.75x0.86英寸,最大空载功率<3W,隔离等级II,具备CEUL安全认证
除非另有要求,否则所有的标准规范在标称输入电流电压、满载和预热后25°C时合理有效深圳市立维创展科技授权代理ARCH电源模块产品,提供高效率,高品质与小尺寸特性的产品满足市场趋势和需求,并提供技术支持服务,欢迎咨询。
详情了解ARCH(翊嘉)电源模块请点击:http://www.leadwaytk.com/public/brand/38.html
或咨询我们的销售工程师:0755-83050846 QQ3312069749
Input Specifications / 輸入規格
Voltage
90~264 VAC or 120~370 VDC
Frequency
47-63 Hz
Inrush Current (<500us)
20 A  (115 VAC) /
50 A  (230 VAC)
(max.)
Leakage Current
0.25 mA
(max.)
Output Specifications / 輸出規格
Power
(max.)
Voltage
3.3, 5, 9, 12, 15, 24
Voltage Accuracy
(Full Load and Nominal Vin)
±10%
Minimum Load
0% (at Full Load)
Line Regulation
(LL to HL at Full Load)
3.3S:±5%
others:±2%
(typ.)
Load Regulation
(0% to 100% at Full Load)
3.3S:±5%
others:±2%
(typ.)
Ripple & Noise
3.3S:<250mV (Vp-p)
5S:<200mV (Vp-p)
9S:<150mV (Vp-p)
12S,15S,24S:<100mV (Vp-p)
(max.)
Protection / 保護規格
Over Power Protection
Hiccup technique, auto-recovery
Over Voltage Protection
Zener diode clamp
Short Circuit Protection
Hiccup mode,
indefinite (automatic recovery)
Environment Specification / 環境規格
Operating Temperature
-40 °C to +85 °C
Storage Temperature
-40 °C to +85 °C
Temperature Coefficient
±0.02% / °C
Humidity
95% RH
SAFETY & EMC
Isolation Voltage
(Input to Output)
3750 VAC
Agency Approvals
UL / IEC / EN 60950-1
EMI
(Conducted & Radiated Emission)
EN 55032 class B
EMS
(Noise Immunity)
EN 55024
Others / 其他
Dimensions
(Tolerance ±0.5mm)
35.7 x 19.0 x 22.0 mm
1.41 x 0.75 x 0.86 inches
Weight
19.9 g
Case Material
Plastic resin with Fiberglass
(flammability to UL 94V-0)
Cooling Method
Free air convection
