51|0
263
SL1203 低噪音、恒定频率开挂电容电压倍增器 [复制链接]
The SL1203 is a low noise, constant
frequency (1.2MHz) switched capacitor voltage
doubler. It produce a regulated output voltage
from a 1.8V to 5V input with up to 100mA of
output current. Low external parts count (one
flying capacitor and two small bypass
capacitors at VIN and VOUT) make the
SL1203 ideally suited for small,
battery-powered applications.
The SL1203 have thermal shutdown
capability and can survive a continuous short
circuit from VOUT to GND. Built-in soft-start
circuitry prevents excessive inrush current
during start-up.
High switching frequency enables the use of
small ceramic capacitors. A low current
shutdown feature disconnects the load from VIN
and reduces quiescent current to <1uA.
The SL1203 is available in the 6-pin SOT23-6.
Fixed 3.3V ± 4% Output
VIN Range: 1.8V to 5V
Output Current: 100mA
Constant Frequency Operation at All Loads
Low Noise Constant Frequency (1.2MHz)
Operation
Automatic Soft-Start Reduces Inrush
Current
Shutdown Current<1uA
Short-Circuit Protection
No Inductors
Available in Low Profile 6-Lead SOT23
Package
2 AA Cell to 3.3V
USB On-The-Go Devices
White LED Drivers
Handheld Devices
Typical Applications
