2604|5
58
AT32F421测评 [复制链接]
        ADC作为片上必备外设有着超高的使用率.虽然一般是10位,12位但在不太严格的场合足够使用.
雅特力也不例外,其片上内嵌1个12位的ADC ,有15个外部通道和3个内部通道(温度传感器、 内部参考电压、和VSSA) ,可以实现单次或扫描转换。支持DMA,模拟看门狗和触发转换.其时钟最高可到28MHz,仅需0.5微秒.
       在at32_board.c中增加ADC的初始化代码.
*		ADC初始化
*		通道3
*   PA3
void ADCX_Init(void)
	RCC_ADCCLKConfig(RCC_APB2CLK_Div6);		//ADC时钟6分频
	RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_ADC1 , ENABLE);
	RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_GPIOA , ENABLE);
	GPIO_InitType           GPIO_InitStructure;
	ADC_InitType            ADC_InitStructure;
	  /* GPIO配置*/
    GPIO_StructInit(&GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pins = GPIO_Pins_3 ;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
		/* ADC1 配置 */
	ADC_StructInit(&ADC_InitStructure);
	ADC_InitStructure.ADC_Mode              = ADC_Mode_Independent;
	ADC_InitStructure.ADC_ScanMode          = DISABLE;
	ADC_InitStructure.ADC_ContinuousMode    = DISABLE;
	ADC_InitStructure.ADC_ExternalTrig      = ADC_ExternalTrig_None;
	ADC_InitStructure.ADC_DataAlign         = ADC_DataAlign_Right;
	ADC_InitStructure.ADC_NumOfChannel      = 1;
	ADC_Init(ADC1, &ADC_InitStructure);
	/* ADC采样通道和采样时间 */
	ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 1, ADC_SampleTime_71_5);
    //转换完成中断
	ADC_INTConfig(ADC1, ADC_INT_EC, ENABLE);
		/* 使能 ADC1 */
	ADC_Ctrl(ADC1, ENABLE);
    /* 校准ADC */
	ADC_RstCalibration(ADC1);
	while(ADC_GetResetCalibrationStatus(ADC1));
	ADC_StartCalibration(ADC1);
	while(ADC_GetCalibrationStatus(ADC1));
	/* 启动ADC转换 */
	ADC_SoftwareStartConvCtrl(ADC1, ENABLE);
at32_board.h中声明一下void ADCX_Init(void);然后添加到
void rt_hw_board_init()
    /* System Clock Update */
    SystemCoreClockUpdate();
    /* System Tick Configuration */
    _SysTick_Config(SystemCoreClock / RT_TICK_PER_SECOND);
	  /* 串口1初始化*/
		UART_Print_Init(115200);
      //ADC初始化
	  ADCX_Init();
    /* Call components board initial (use INIT_BOARD_EXPORT()) */
#ifdef RT_USING_COMPONENTS_INIT
     rt_components_board_init();
#endif
#if defined(RT_USING_USER_MAIN) && defined(RT_USING_HEAP)
    rt_system_heap_init(rt_heap_begin_get(), rt_heap_end_get());
#endif
        在main中初始化线程控制块,及线程入口函数.
 * 变量
 //ADC转换值
 uint16_t ADC_value;
 /* 定义线程栈4字节对齐 */
 ALIGN(RT_ALIGN_SIZE)
 /* 定义线程控制块 */
 static struct rt_thread ADC_thread;
 /* 定义线程栈大小 */
 static rt_uint8_t ADC_stack[192];
 * 函数声明
 static void ADC_thread_entry(void *parameter);
  * [url=home.php?mod=space&uid=159083]@brief[/url] Main program
  * @param  None
  * @retval None
int main(void)
	rt_err_t result;
    /* 初始化ADC线程控制块 */
    result = rt_thread_init(&ADC_thread,
                            "ADC",
                            ADC_thread_entry,
                            RT_NULL,
                            (rt_uint8_t *)&ADC_stack[0],
                            sizeof(ADC_stack),
                            5,
                            5);
    if (result == RT_EOK)
        rt_thread_startup(&ADC_thread);
    return 0;
    while (1)
         if(ADC_GetINTStatus(ADC1, ADC_INT_EC) != RESET){
				 ADC_value=ADC_GetConversionValue(ADC1);
	       rt_kprintf("ADC_value: %d \r\n",ADC_value);
	       rt_thread_mdelay(500);
				 /* 启动ADC转换 */
       由于rt_kprintf不支持输出浮点数这里就直接输出转换后的值了.
       在配置线程栈大小时候可以先大致给一个,然后在控制台中用ps命令查看一下栈使用率,一般维持在七十多比较好.为了方便截图这里暂时断开连接了.
旋转电位器可以看到转换值的变化
硬件连接
看起来指标还行,你这表确实没听说过。。。   详情 回复 发表于 2021-5-16 21:33
6828
10位的ADC平时足够用了
是的,这个rt_kprintf不支持输出浮点数
期待下来的楼主测评
管理员
针对一个外设的评测挺好的,期待后续。
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
7671
谢谢分享,如果有标准AD值和采样之间的精度对比就好了
  首先说明一下我用的表是手持三位半的国产垃圾表,这种小电压精度还是差点意思的,第一张图是600mv档,第二张图是6v档.其次ADC外部我没加RC所以adc采到的精度也有误差具体多少就不知道了,反正家里是没条件折腾  详情 回复 发表于 2021-5-16 13:08
默认摸鱼,再摸鱼。2022、9、28
58
freebsder 发表于 2021-5-12 09:49 谢谢分享,如果有标准AD值和采样之间的精度对比就好了
首先说明一下我用的表是手持三位半的国产垃圾表,这种小电压精度还是差点意思的,第一张图是600mv档,第二张图是6v档.其次ADC外部我没加RC所以adc采到的精度也有误差具体多少就不知道了,反正家里是没条件折腾.
万用表是每秒采集只有几次所以ADC我是采集4次算的平均值.大概600毫秒多一点更新一次.仅供参考.
7671
默认摸鱼,再摸鱼。2022、9、28
