335|2
【RPi PICO】计算Mandelbrot [复制链接]
将micropython源码中的examples/mandel.py例子修改了一下,用于测试计算性能
from time import ticks_ms, ticks_diff
def run(func, param = None):
    t1 = ticks_ms()
    if param == None:
        func()
    else:
        func(param)
    t2 = ticks_ms()
    print('calc time:', ticks_diff(t2, t1), 'ms')
def mandelbrot():
    # returns True if c, complex, is in the Mandelbrot set
    # @micropython.native
    def in_set(c):
        z = 0
        for i in range(40):
            z = z * z + c
            if abs(z) > 4:
                return False
        return True
    for v in range(31):
        for u in range(81):
            if in_set((u / 30 - 2) + (v / 15 - 1) * 1j):
                print(' ', end='')
            else:
                print('#', end='')
        print()
run(mandelbrot)
运行结果
赞赏
查看全部赞赏
circuitpython版本程序
from time import monotonic
    t1 = monotonic()
    if param == None:
        func()
    else:
        func(param)
    t2 = monotonic()
    print('calc time:', round((t2 - t1)*1000), 'ms')
def mandelbrot():
    def in_set(c):
        z = 0
        for i in range(40):
            z = z * z + c
            if abs(z) > 4:
                return False
        return True
    for v in range(31):
        for u in range(81):
                print(' ', end='')
            else:
                print('>', end='')
        print()
run(mandelbrot)
785
感谢分享!!!
