345|4
【RPi PICO】土壤湿度指示器 [复制链接]
来自:https://andywarburton.co.uk/raspberry-pi-pico-soil-moisture-sensor/
需要的材料
  • Raspberry Pi Pico
  • 一个Sparkfun土壤湿度传感器
  • WS2812B(Neopixel)环或带
连线图
  • 引脚2-Neopixel ring的数据信号
  • 引脚7-湿度传感器的电源
  • 引脚40-Neopixel环的电源(直接从USB端口)
  • 引脚38-Neopixel环的地
  • 引脚27-湿度传感器的模拟信号
  • 引脚23-湿度传感器的地
赞赏
查看全部赞赏
代码
编程前,需要先安装circuitpython到PICO板,并下载必要的绑定库(请参考PICO文档的链接)。
import time
import board
import neopixel
from analogio import AnalogIn
from digitalio import DigitalInOut, Direction, Pull
# how frequently to take readings
DELAY = 600
# Update this to match the number of NeoPixel LEDs connected to your board.
num_pixels = 16
# setup the moisture sensor power pin and turn it off by default
sensor_power = DigitalInOut(board.GP7)
sensor_power.direction = Direction.OUTPUT
sensor_power.value = False
# set the analog read pin for the moisture sensor
sensor_signal = AnalogIn(board.GP27)
# set up the noepixels
pixels = neopixel.NeoPixel(board.GP1, num_pixels, auto_write=False)
pixels.brightness = 0.2
# some variables for internal use, you shouldn't have to worry about them
calibrate_count = 0
auto_calibrate = True
SENSOR_MAX = 0
SENSOR_MIN = 9999
# set the neopixels to blue
for i in range(num_pixels):
    pixels[i] = (0,0,255)
pixels.show()
print("=============")
print("calibrating sensor")
print("=============\n\n")
while True:
    if auto_calibrate == True:
        # enable the sensor power
        sensor_power.value = True
        # take a reading from the sensor and make it a little easier to read
        value = round(sensor_signal.value / 100)
        # disable the sensor power
        print("reading:", value)
        if value > SENSOR_MAX:
            SENSOR_MAX = value
        if value < SENSOR_MIN:
            SENSOR_MIN = value
        calibrate_count += 1
        if(calibrate_count > 100):
            print("\n-------------------")
            print("MIN:", SENSOR_MIN)
            print("MAX:", SENSOR_MAX)
            print("-------------------\n")
            time.sleep(5)
            # wipe pixels
                pixels[i] = (0,0,0)
            pixels.show()
            auto_calibrate = False
        time.sleep(0.2)
    else:
        # crazy math to turn value into percentage
        percent = round(((value - SENSOR_MIN) / (SENSOR_MAX - SENSOR_MIN)) * 100)
        print("Percent:", percent)
        # more crazy math to convert percentage to number of pixels
        show_leds = round(100 / (100 / num_pixels) * percent / 100)
        print("leds to show:", show_leds)
        # print values for the plotter
        print((value, percent, show_leds))
        # change colour depending on quantity
        if(show_leds < 8):
            color = (255,0,0)
        else:
            color = (0,255,0)
        # make sure we don't ever try to show more leds than we have
        # because that will crash the script
        if(show_leds > num_pixels):
            show_leds = num_pixels
        # if water levels are critically low, show them all
        if(show_leds <= 3):
        # wipe pixels
            pixels[i] = (0,0,0)
        # turn on neopixels
        for i in range(show_leds):
            pixels[i] = color
        pixels.show()
        # wait for required delay
        time.sleep(DELAY)
        print("\n-------------------\n")
795
测评写的不错,就喜欢你这样的测评帖子,感谢老铁的分享!期待后续
114
这种湿度传感器要不了多久就坏了,换个电容式的吧,或者自己用两个不锈钢片自制个模拟的。
278
感谢分享
