503|4
【RPi PICO】Programmable IO例子 [复制链接]
这是官方文档带有的一个例子,
from rp2 import PIO, StateMachine, asm_pio
from machine import Pin
import time
@asm_pio(set_init=PIO.OUT_LOW)
def led_quarter_brightness():
    set(pins, 0) [2]
    set(pins, 1)
def led_half_brightness():
    set(pins, 0)
    set(pins, 1)
@asm_pio(set_init=PIO.OUT_HIGH)
def led_full_brightness():
    set(pins, 1)
sm1 = StateMachine(1, led_quarter_brightness, freq=10000, set_base=Pin(25))
sm2 = StateMachine(2, led_half_brightness, freq=10000, set_base=Pin(25))
sm3 = StateMachine(3, led_full_brightness, freq=10000, set_base=Pin(25))
while(True):
    sm1.active(1)
    time.sleep(1)
    sm1.active(0)
    sm2.active(1)
    time.sleep(1)
    sm2.active(0)
    sm3.active(1)
    time.sleep(1)
    sm3.active(0)
如果运行时提示错误,找不到array模块,请升级micropython固件。
https://micropython.org/download/rp2-pico/
754
rp2-pico/的micropython固件更新的好快,最近2天一更新,
最近固件bug比较多,所以更新也快。  详情 回复 发表于 2021-2-7 17:22
fxyc87 发表于 2021-2-7 16:48 rp2-pico/的micropython固件更新的好快,最近2天一更新,
最近固件bug比较多,所以更新也快。
794
Programmable IO有什么特点呢,楼主。
