455|11
65
【RISC-V MCU CH32V103测评】- 3:USART - 为什么试了三个串口工具都不行? [复制链接]
这次测评的对象是:USART,依据是:《CH32V103应用教程——USART》。
首先,文档看过以后,有一点不明白,在第4页,关于"void USART ReceiveWakeUpCmd",介绍说,“功能:确定USART是否处于静音模式,不明白“WakeUp”何以对应“静音”。
其次,接线:
用了6根双母口的跳线:
WCH-Link               CH32V103C-RO-1v2
5v                            5v
GND                        GND
SWCLK                   SWCLK
SWDIO                    SWDIO
TX                            PA3
RX                            PA2
代码:
usart.h
#ifndef __USART_H
#define __USART_H
#include "ch32v10x_conf.h"
void USARTx_CFG(void);
void USARTx_SendByte(USART_TypeDef* pUSARTx, uint8_t data);
void USARTx_SendStr(USART_TypeDef* pUSARTx, char* str);
void USART2_IRQHandler(void);
#endif
usart.c
#include "usart.h"
void USART2_IRQHandler(void)__attribute__((interrupt("WCH-Interrupt-fast")));
void USARTx_CFG(void) {
    GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    USART_DeInit(USART2);
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
    USART_Init(USART2, &USART_InitStructure);
    USART_Cmd(USART2, ENABLE);
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
void USARTx_SendByte(USART_TypeDef* pUSARTx, uint8_t data) {
    USART_SendData(pUSARTx, data);
    while(USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET);
void USARTx_SendStr(USART_TypeDef* pUSARTx, char* str) {
    uint8_t i = 0;
    do {
        USARTx_SendByte(pUSARTx, *(str + i));
        i++;
    } while(*(str + i) != '\n');
    while(USART_GetFlagStatus(pUSARTx, USART_FLAG_TC) == RESET);
void USART_IRQHandler(void) {
    uint8_t ucTemp;
    if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) {
        USART_ClearITPendingBit(USART2, USART_IT_RXNE);
        ucTemp = USART_ReceiveData(USART2);
        USART_SendData(USART2, ucTemp);
main.c
#include "debug.h"
#include "usart.h"
int main(void) {
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
    USARTx_CFG();
    USARTx_SendStr(USART2, "This is a test string.\n");
    while(1);
上述代码,个别细节跟原文不一样,做了一点调整,但就是不做调整,依然是编译下载没有问题,却在Putty、Tera Term、VS Code三个串口工具中都没有显示,有谁知道这是为什么。
7938
用示波器看看总线的波形呢?
示波器测试的结果,PA2和PA3都没有输出信号。  详情 回复 发表于 2021-2-3 09:16
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
3313
回环模式先测试一下。
个人签名人已离开,无事别找,找也找不到。
3423
连接不知道对不?应该可以通的。还有调试的时候要注意一下那个调试器驱动。看看是否好了。
65
连接是这样。
65
是我的串口调试工具的使用方法不对吗?我试了深圳宏晶的“stc-isp-15xx-v6”,也还是不行,都能找到串口,前三个都能提示已经连接上,但是看不到内容。
楼主接错线了吧,都在那个插排上接,怎么还有两根往大插排走了
往大插排上去的是PA2和PA3。  详情 回复 发表于 2021-2-3 08:19
65
ddllxxrr 发表于 2021-2-2 20:09 楼主接错线了吧,都在那个插排上接,怎么还有两根往大插排走了
往大插排上去的是PA2和PA3。
65
littleshrimp 发表于 2021-2-2 12:17 用示波器看看总线的波形呢?
PA2,PA3一个是单片机的数据发送,另一个是电脑的数据发送,你可以让电脑循环发送数据,看一下是不是有一条线上能看到数据。 然后你再把单片机的USARTx_SendStr放到循环里,这样能保证数据线上一直有数据,再用示  详情 回复 发表于 2021-2-3 09:46
7938
MianQi 发表于 2021-2-3 09:16 示波器测试的结果,PA2和PA3都没有输出信号。
然后你再把单片机的USARTx_SendStr放到循环里,这样能保证数据线上一直有数据,再用示波器看一下。
[attachimg]524147[/attachimg] 还没有按照你的说法做,现在测的结果,PA2和PA3都没有信号输出。  详情 回复 发表于 2021-2-3 10:12
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
133
管理员
问题解决了吗??有问题可以问下沁恒的技术@沁恒USB单片机
玩板看这里:
http://bbs.eeworld.com.cn/elecplay.html
65
littleshrimp 发表于 2021-2-3 09:46 PA2,PA3一个是单片机的数据发送,另一个是电脑的数据发送,你可以让电脑循环发送数据,看一下是不是有一 ...
65
刚才又逐行对照了一下教程,有两行代码的位置我调整了一下,恢复成教程里的位置。这是我打开串口的过程,有什么问题吗?
试试使用GPIO模式用示波器看一下PA2和PA3能不能正常输出,排除硬件连接问题。  详情 回复 发表于 2021-2-4 08:37
7938
MianQi 发表于 2021-2-3 18:28 刚才又逐行对照了一下教程,有两行代码的位置我调整了一下,恢复成教程里的位置。这是我打开串口的过程, ...
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
