406|2
334
【测评SGP40】快速部署实现的人工智能环境空气质量跟踪模型 #2 上电测试的arduino篇 [复制链接]
1、在开箱之后,现在获得的资料之后,用arduino代码开始测试。
具体连接参见上贴子,可以连接UART,如下图,其中UART选择SEL为悬空。
2、 不过从代码分析看,只是支持I2C读取。
#include "sgp40_voc_index.h"
void setup() {
  int16_t err;
  Serial.begin(115200);  // start serial for output
  // wait for serial connection from PC
  // comment the following line if you'd like the output
  // without waiting for the interface being ready
  while(!Serial);
  /* Initialize I2C bus, SHT, SGP and VOC Engine */
  while ((err = sensirion_init_sensors())) {
    Serial.print("initialization failed: ");
    Serial.println(err);
    sensirion_sleep_usec(1000000); /* wait one second */
  Serial.println("initialization successful");
/* Run one measurement per second */
void loop() {
  int16_t err;
  int32_t voc_index;
  int32_t temperature_celsius;
  int32_t relative_humidity_percent;
  err = sensirion_measure_voc_index_with_rh_t(
          &voc_index, &relative_humidity_percent, &temperature_celsius );
  if (err == STATUS_OK) {
    Serial.print("VOCindex:");
    Serial.print(voc_index);
    Serial.print("\t");
    Serial.print("Humidity[%RH]:");
    Serial.print(relative_humidity_percent * 0.001f);
    Serial.print("\t");
    Serial.print("Temperature[degC]:");
    Serial.println(temperature_celsius * 0.001f);
  } else {
    Serial.print("error reading signal: ");
头文件如下,
#include "sensirion_arch_config.h"
#include "sensirion_voc_algorithm.h"
#include "sgp40.h"
#include "shtc1.h"
#ifdef __cplusplus
extern "C" {
#endif
static VocAlgorithmParams voc_algorithm_params;
int16_t sensirion_init_sensors() {
    int16_t ret;
    sensirion_i2c_init();
    ret = shtc1_probe();
    if (ret)
        return SENSIRION_SHT_PROBE_FAILED;
    ret = sgp40_probe();
    if (ret)
        return SENSIRION_SGP_PROBE_FAILED;
    VocAlgorithm_init(&voc_algorithm_params);
    return 0;
int16_t sensirion_measure_voc_index(int32_t* voc_index) {
    return sensirion_measure_voc_index_with_rh_t(voc_index, NULL, NULL);
int16_t sensirion_measure_voc_index_with_rh_t(int32_t* voc_index,
                                              int32_t* relative_humidity,
                                              int32_t* temperature) {
    int32_t int_temperature, int_humidity;
    int16_t ret;
    uint16_t sraw;
    ret = shtc1_measure_blocking_read(&int_temperature, &int_humidity);
    if (ret)
        return SENSIRION_GET_RHT_SIGNAL_FAILED;
    if (temperature) {
        *temperature = int_temperature;
    if (relative_humidity) {
        *relative_humidity = int_humidity;
    ret = sgp40_measure_raw_with_rht_blocking_read(int_humidity,
                                                   int_temperature, &sraw);
    if (ret) {
        return SENSIRION_GET_SGP_SIGNAL_FAILED;
    VocAlgorithm_process(&voc_algorithm_params, sraw, voc_index);
    return 0;
#ifdef __cplusplus
#endif
不过下载代码后没有正确启动数据,读取失败。就是如下指令返回的是读取错误。
这下进度就受阻了,需要分析看为什么这样的情况出现。
此帖出自传感器论坛
646
这个有点坑爹,i2c需要外接上拉电阻,板子上没有。。。我测试也是这种情况。。。不能开箱即用,串口呢,没有Arduino驱动,也没有其它微控制器的串口驱动,坑爹。好在协议简单,我自己写了,啥时候空了发出来。
nmg
是板子设计的问题吗?  详情 回复 发表于 昨天 11:33
赞赏
查看全部赞赏
4311
233
管理员
dql2016 发表于 2021-2-1 13:25 这个有点坑爹,i2c需要外接上拉电阻,板子上没有。。。我测试也是这种情况。。。不能开箱即用,串口呢,没 ...
是板子设计的问题吗?
