384|2
1449
CH32V103的SPI有跑通的吗? [复制链接]
这几天有跑通SPI总线的朋友吗?我三天的时间在跑SPI,结果通过示波器连信号都有没有发现。知道的朋友给个提示
PA5 -->SPI_CLK
PA7 -->SPI_MOSI
* Function Name  : SPI_FullDuplex_Init
* Description    : Configuring the SPI for full-duplex communication.
* Input          : None
* Return         : None
void SPI_FullDuplex_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    SPI_InitTypeDef SPI_InitStructure;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1, ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOA, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init( SPI1, &SPI_InitStructure );
    SPI_Cmd( SPI1, ENABLE );
// Send a byte to the command register
void ssd1306_WriteCommand(uint8_t byte) {
    GPIO_WriteBit(SSD1306_CS_Port, SSD1306_CS_Pin, GPIO_PIN_RESET); // select OLED
    GPIO_WriteBit(SSD1306_DC_Port, SSD1306_DC_Pin, GPIO_PIN_RESET); // command
    SPI_I2S_SendData(SSD1306_SPI_PORT,byte);
    GPIO_WriteBit(SSD1306_CS_Port, SSD1306_CS_Pin, GPIO_PIN_SET); // un-select OLED
void SPI_Transmit(SPI_TypeDef* SPIx,u8* TxData, u16 TxData_size)
    u16 i = 0;
    for(i=0;i<TxData_size;i++)
        if( SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_TXE ) != RESET )
             SPI_I2S_SendData(SPIx, TxData[i]);
// Send data
void ssd1306_WriteData(u8 * TxData, u16 TxData_size) {
    GPIO_WriteBit(SSD1306_DC_Port, SSD1306_DC_Pin, GPIO_PIN_SET); // data
    SPI_Transmit(SSD1306_SPI_PORT, TxData, TxData_size);
    // value = memcmp( TxData, RxData, Size );
主程序中的调用情况。我在ssd1306_Init程序中调用SPI发出信号。
	u8 i=0;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    Delay_Init();
	USART_Printf_Init(115200);
	printf("SystemClk:%d\r\n",SystemCoreClock);
	GPIO_Toggle_INIT();
	SPI_FullDuplex_Init();
	Delay_Ms(2000);
	printf("This is SPI  example\r\n");
	GPIO_WriteBit(GPIOB, GPIO_Pin_11, Bit_SET);
	ssd1306_Init();
	//GPIO_WriteBit(GPIOB, GPIO_Pin_11, Bit_RESET);
	printf("Host Mode\r\n");
引脚的初始化是这样的。
* Function Name  : GPIO_Toggle_INIT
* Description    : Initializes GPIOA.0
* Input          : None
* Return         : None
void GPIO_Toggle_INIT(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
      GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
      GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
      GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
1449
OLED屏幕是测试好的。在STM32G431开发板上是好的
23
我也是用硬件spi驱不起来,想debug下也报端口错误,你解决没
    站长推荐上一条 1/4 下一条
