525|7
716
【NUCLEO-L452RE测评】+2.2寸TFT显示屏的驱动显示 [复制链接]
前文介绍了以STM32L452RE来驱动OLED屏,但它的屏幕比较小,这次就用它来驱动2.2TFT显示屏。
鉴于STM32L452RE开发板配有Arduino接口,因此就直接利用它来连接TFT显示屏,该显示屏与MCU的连接关系为:
CS ---PA5
RST--- PA6
D/C---PA7
SDI--- PB6
SCK---PC7
LED--- PA9
输出高低电平的语句定义为:
#define LCD_CS_High()       HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET)   // PA5
#define LCD_CS_Low()               HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_RESET)
#define LCD_REST_High()     HAL_GPIO_WritePin(GPIOA,GPIO_PIN_6,GPIO_PIN_SET)    // PA6
#define LCD_REST_Low()      HAL_GPIO_WritePin(GPIOA,GPIO_PIN_6,GPIO_PIN_RESET)
#define LCD_DC_High()       HAL_GPIO_WritePin(GPIOA,GPIO_PIN_7,GPIO_PIN_SET)    // PA7
#define LCD_DC_Low()        HAL_GPIO_WritePin(GPIOA,GPIO_PIN_7,GPIO_PIN_RESET)
#define LCD_SDI_High()      HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6,GPIO_PIN_SET)   // PB6
#define LCD_SDI_Low()       HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6,GPIO_PIN_RESET)
#define LCD_SCK_High()      HAL_GPIO_WritePin(GPIOC,GPIO_PIN_7,GPIO_PIN_SET)   // PC7
#define LCD_SCK_Low()             HAL_GPIO_WritePin(GPIOC,GPIO_PIN_7,GPIO_PIN_RESET)
#define LCD_LED_High()      HAL_GPIO_WritePin(GPIOA,GPIO_PIN_9,GPIO_PIN_SET)     // PA9
引脚输出功能的配置函数为:
void APP_TFT_init(void)
    __HAL_RCC_GPIOA_CLK_ENABLE();
    GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Pin = GPIO_PIN_5;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_6;
    GPIO_InitStruct.Pin = GPIO_PIN_7;
    GPIO_InitStruct.Pin = GPIO_PIN_9;
    __HAL_RCC_GPIOB_CLK_ENABLE();
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    __HAL_RCC_GPIOC_CLK_ENABLE();
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    LCD_LED_High();
实现图片显示的函数为:
void show_pic(const unsigned char *p)
        int i,j;
        unsigned char picH,picL;
        Address_set(0,0,LCD_W-1,LCD_H-1);
        for(i=0;i<240;i++)
           for(j=0;j<320;j++)
               picH=*p++;
               picL=*p++;
               LCD_WR_DATA8(picH);
               LCD_WR_DATA8(picL);
实现显示效果的主程序为:
int main(void)
    HAL_Init();
    /* Configure the system clock to 80 MHz */
    SystemClock_Config();
    APP_TFT_init();
    LCD_Init();
    //LCD_Clear(WHITE);
    show_pic(gImage_a);
    while (1);
经程序的编译下载,其显示效果如图所示。
显示效果
如果2.2TFT显示屏还显小的话,后面咱再上个2.8寸触摸屏。
此帖出自stm32/stm8论坛
3244
美女可以,就是分辨率不行。
你心目中最基本的分辨率是个啥标准呀?  详情 回复 发表于 2020-12-25 20:11
个人签名人已离开,无事别找,找也找不到。
716
freebsder 发表于 2020-12-25 18:24 美女可以,就是分辨率不行。
你心目中最基本的分辨率是个啥标准呀?
775
我觉得这个屏幕更适合我。哈哈!
是,这块屏能直接插到Arduino接口来用,省去了连线比较方便。2.8寸的触摸屏就不行了,部分引脚没法直接插到插排中,就只能连线了。  详情 回复 发表于 2020-12-26 11:02
716
w494143467 发表于 2020-12-26 10:41 我觉得这个屏幕更适合我。哈哈!
SOGA,那我得有一个这样的屏幕,应该现在很多开发板都拥有Arduino的接口。  详情 回复 发表于 2020-12-26 17:43
775
jinglixixi 发表于 2020-12-26 11:02 是,这块屏能直接插到Arduino接口来用,省去了连线比较方便。2.8寸的触摸屏就不行了,部分引脚没法直接插 ...
没错,是这样。  详情 回复 发表于 2020-12-26 20:23
716
w494143467 发表于 2020-12-26 17:43 SOGA,那我得有一个这样的屏幕,应该现在很多开发板都拥有Arduino的接口。
没错,是这样。
133
管理员
玩板看这里:
http://bbs.eeworld.com.cn/elecplay.html
