1360|7
1059
【GD32307E-START】+ 双色OLED屏驱动显示 [复制链接]
有了前面LED与KEY的使用经验,现在就可以在它的基础上盖房子了,先完成一个简单的,就是使用I/O模拟I2C通讯来驱动OLED屏。
由于开发板所配置外设资源十分有限,故所占用的引脚资源很少,用起来便有些随心所欲了。
为图省事,这里OLED屏与MCU的连接关系如下:
SCLK---PC0
SDIN ---PC1
相关引脚输出高低电平的语句定义为:
#define OLED_SCLK_Clr()  GPIO_BC(GPIOC) = GPIO_PIN_0
#define OLED_SCLK_Set()  GPIO_BOP(GPIOC) = GPIO_PIN_0
#define OLED_SDIN_Clr()  GPIO_BC(GPIOC) = GPIO_PIN_1
#define OLED_SDIN_Set()  GPIO_BOP(GPIOC) = GPIO_PIN_1
而引脚功能配置的函数为:
void  gd_eval_oled_init(void)
    rcu_periph_clock_enable(RCU_GPIOC);
    gpio_init(GPIOC, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_0|GPIO_PIN_1);
    GPIO_BC(GPIOC) = GPIO_PIN_0;
    GPIO_BC(GPIOC) = GPIO_PIN_1;
OLED屏的初始化函数为:
void OLED_Init(void)
    Write_IIC_Command(0xAE); //display off
    Write_IIC_Command(0x20); //Set Memory Addressing Mode
    Write_IIC_Command(0x10);
    Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
    Write_IIC_Command(0xc8);//Set COM Output Scan Direction
    Write_IIC_Command(0x00);//---set low column address
    Write_IIC_Command(0x10);//---set high column address
    Write_IIC_Command(0x40);//--set start line address
    Write_IIC_Command(0x81);//--set contrast control register
    Write_IIC_Command(0xdf);
    Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
    Write_IIC_Command(0xa6);//--set normal display
    Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
    Write_IIC_Command(0x3F);//
    Write_IIC_Command(0xa4);//
    Write_IIC_Command(0xd3);//-set display offset
    Write_IIC_Command(0x00);//-not offset
    Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
    Write_IIC_Command(0xf0);//--set divide ratio
    Write_IIC_Command(0xd9);//--set pre-charge period
    Write_IIC_Command(0x22); //
    Write_IIC_Command(0xda);//--set com pins hardware configuration
    Write_IIC_Command(0x12);
    Write_IIC_Command(0xdb);//--set vcomh
    Write_IIC_Command(0x20);//0x20,0.77xVcc
    Write_IIC_Command(0x8d);//--set DC-DC enable
    Write_IIC_Command(0x14);//
    Write_IIC_Command(0xaf);//--turn on oled panel
值得指出的是,由于GD32307E的处理速度实在是快,故以往在IIC_Start()函数中是无需添加延时的,而如今不添加就无法完成显示的功能,
更新后的IIC_Start()函数如下:
void IIC_Start()
           OLED_SCLK_Set();
           delay_us(10);
           OLED_SDIN_Set();
           delay_us(10);
           OLED_SDIN_Clr();
           delay_us(10);
           OLED_SCLK_Clr();
           delay_us(10);
实现图示显示效果的主程序如下:
int main(void)
           gd_eval_oled_init();
           OLED_Init();
           OLED_Clear();
           OLED_ShowString(0,0,"GD32F307 TEST",16);
           OLED_ShowString(0,2,"OLED DISPLAY",16);
           OLED_ShowString(0,4,"jinglixixi",16);
           OLED_ShowString(0,6,"2020.11.8",16);
           while(1){
OLED屏显示效果
1998
哈哈,是不是OLED显示是测评的必选之一。
此外,我们看不到的,有多数是别人碰过钉子无法实现的,例如DHT11/DHT22是很普通的传感器,它在使用上我发现会在我用过的MCU上有1/4是无法实现的,不信你可以去试,使用的人多是看别人用过,才确定它是可行的,如果  详情 回复 发表于 2020-11-15 08:47
嘿嘿,那到不是,但起码每种开发板的性能是不一样的,你要知道他能支持什么,以及如何实现。比如这个屏吧,在大多数的开发板上其IIC_Start()函数中是无需加延时的,可能是GD32307E的主频速度太快了,没有延时是不能  详情 回复 发表于 2020-11-15 08:39
4719
谢谢分享@
默认摸鱼
1059
w494143467 发表于 2020-11-14 21:19 哈哈,是不是OLED显示是测评的必选之一。
嘿嘿,那到不是,但起码每种开发板的性能是不一样的,你要知道他能支持什么,以及如何实现。比如这个屏吧,在大多数的开发板上其IIC_Start()函数中是无需加延时的,可能是GD32307E的主频速度太快了,没有延时是不能显示的,你不尝试一下可能会认为它不支持此OLED屏了其实不然,你说这样做有无意义呢?我们做过了,在用到时,或是其它人使用时心里才有底,做方案时才踏实!
1059
1059
此外,我们看不到的,有多数是别人碰过钉子无法实现的,例如DHT11/DHT22是很普通的传感器,它在使用上我发现会在我用过的MCU上有1/4是无法实现的,不信你可以去试,使用的人多是看别人用过,才确定它是可行的,如果找不到先例,多半,呵呵。。。
对,这倒也是,让大家觉得这个OLED屏幕是可以驱动起来的!点赞  详情 回复 发表于 2020-11-15 10:56
1998
jinglixixi 发表于 2020-11-15 08:47 此外,我们看不到的,有多数是别人碰过钉子无法实现的,例如DHT11/DHT22是很普通的传感器,它在使用上我 ...
此外,OLED屏尤其是I2C接口,占用引脚资源仅次于LED,但所表达的内容却是LED不能同日而语的呀!  详情 回复 发表于 2020-11-15 14:10
1059
w494143467 发表于 2020-11-15 10:56 对,这倒也是,让大家觉得这个OLED屏幕是可以驱动起来的!点赞
