【MM32 eMiniBoard测评】+OLED屏的驱动显示
1.使用GPIO口模拟I2C接口
在例程中提供了一个LED灯闪烁程序,通过它我们可以掌握控制GPIO口定义输出口及输出高低电平信号的方法,据此可用GPIO口来模拟I2C接口以控制该接口形式的OLED显示屏它该OLED显示屏具有占用引脚少,显示信息量较多的特点。
在引脚的分配上,用PB6来连接OLED屏的SCK引脚,用PB7来连接OLED屏的SDA引脚,为此其输出高低的定义为:
#define OLED_SCLK_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_13)
#define OLED_SCLK_Set() GPIO_SetBits(GPIOB,GPIO_Pin_13)
#define OLED_SDIN_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_14)
#define OLED_SDIN_Set() GPIO_SetBits(GPIOB,GPIO_Pin_14)
引脚输出功能的配置函数为:
void APP_OLED_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
相应的OLED显示屏的初始化函数为:
void OLED_Init(void)
Write_IIC_Command(0xAE); //display off
Write_IIC_Command(0x20); //Set Memory Addressing Mode
Write_IIC_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
Write_IIC_Command(0xc8);//Set COM Output Scan Direction
Write_IIC_Command(0x00);//---set low column address
Write_IIC_Command(0x10);//---set high column address
Write_IIC_Command(0x40);//--set start line address
Write_IIC_Command(0x81);//--set contrast control register
Write_IIC_Command(0xdf);
Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
Write_IIC_Command(0xa6);//--set normal display
Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
Write_IIC_Command(0x3F);//
Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
Write_IIC_Command(0xd3);//-set display offset
Write_IIC_Command(0x00);//-not offset
Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
Write_IIC_Command(0xf0);//--set divide ratio
Write_IIC_Command(0xd9);//--set pre-charge period
Write_IIC_Command(0x22); //
Write_IIC_Command(0xda);//--set com pins hardware configuration
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb);//--set vcomh
Write_IIC_Command(0x20);//0x20,0.77xVcc
Write_IIC_Command(0x8d);//--set DC-DC enable
Write_IIC_Command(0x14);//
Write_IIC_Command(0xaf);//--turn on oled panel
2. OLED屏显示驱动
在完成功能引脚定义及初始化的基础下,要实现具体的字符及数值的显示,需相关函数的配合,关键的函数为:
void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
unsigned char c=0,i=0;
c=chr-' ';
if(x>Max_Column-1){x=0;y=y+2;}
if(Char_Size ==16)
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
else {
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WR_Byte(F6x8[c],OLED_DATA);
uint32_t oled_pow(uint8_t m,uint8_t n)
uint32_t result=1;
while(n--)result*=m;
return result;
void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size2)
uint8_t t,temp;
uint8_t enshow=0;
for(t=0;t<len;t++)
temp=(num/oled_pow(10,len-t-1))%10;
if(enshow==0&&t<(len-1))
if(temp==0)
OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
continue;
}else enshow=1;
OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
unsigned char j=0;
while (chr[j]!='\0')
{ OLED_ShowChar(x,y,chr[j],Char_Size);
x+=8;
if(x>120){x=0;y+=2;}
j++;
3.显示功能的测试
为了测试OLED屏的显示功能,其主函数如下:
s32 main(void)
APP_OLED_Init();
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"MM32F0133 TEST",16);
OLED_ShowString(0,2,"OLED Display",16);
while(1);
相应的显示效果如图所示,后面就可以为其添加具体的应用功能了。
显示效果图
