2879|0
3836
【DSP】TMS320F28035 SCI例程(自发自收+查询) [复制链接]
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
void scia_loopback_init(void);
void scia_fifo_init(void);
void error();
Uint16 LoopCount;
Uint16 ErrorCount;
Uint16 SendChar;
Uint16 ReceivedChar;
void main(void)
    InitSysCtrl();
    InitSciGpio();//初始化SCI引脚
    DINT;
    IER = 0x0000;
    IFR = 0x0000;
    InitPieVectTable();
    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;//使能PIE
    PieCtrlRegs.PIEACK.all = 0xFFFF;//写1清零,允许所有PIE都能被响应
    EINT;//开启总中断
    LoopCount = 0;
    ErrorCount = 0;
    scia_fifo_init();      // Initialize the SCI FIFO
    scia_loopback_init();  // Initalize SCI for digital loop back
    SendChar = 0;
    for(;;)
       DELAY_US(1000000);
       //将要发送的数据存入SCITXBUF
       SciaRegs.SCITXBUF = SendChar;
       //等待发送完成
       while(SciaRegs.SCIFFRX.bit.RXFFST !=1) { } // wait for RRDY/RXFFST =1 for 1 data available in FIFO
       //存储接收数据
       ReceivedChar = SciaRegs.SCIRXBUF.all;
       //自检
       if(ReceivedChar != SendChar) error();
       //发送的数据
       SendChar++;
       // Limit the character to 8-bits
       SendChar &= 0x00FF;
       LoopCount++;
// Step 7. Insert all local Interrupt Service Routines (ISRs) and functions here:
void error()
      ErrorCount++;
// Test 1,SCIA  DLB, 8-bit word, baud rate 0x000F, default, 1 STOP bit, no parity
void scia_loopback_init()
    SciaRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
    //配置通讯协议                               // No parity,8 char bits,
                                   // async mode, idle-line protocol
    SciaRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
    SciaRegs.SCICTL2.all =0x0003;
    SciaRegs.SCICTL2.bit.TXINTENA =1;
    SciaRegs.SCICTL2.bit.RXBKINTENA =1;
    SciaRegs.SCIHBAUD    =0x0000;
    SciaRegs.SCILBAUD    =0x000F;
    SciaRegs.SCICCR.bit.LOOPBKENA =1; // Enable loop back
    SciaRegs.SCICTL1.all =0x0023;     // Relinquish SCI from Reset
// Initalize the SCI FIFO
void scia_fifo_init()
    SciaRegs.SCIFFTX.all=0xE040;
    SciaRegs.SCIFFRX.all=0x2044;
    SciaRegs.SCIFFCT.all=0x0;
