643|4
122
关于树莓派通过蓝牙连接SensorTile.box [复制链接]
打开系统蓝牙
sudo service bluetooth start
进入bluetoothctl
Sudo bluetoothctl
输入以下命令
power on
agent on
default-agent
scan on
pair C0:50:27:32:09:33
连接成功以后
[bluetooth]# pair c0:50:27:32:09:33
Attempting to pair with C0:50:27:32:09:33
[CHG] Device C0:50:27:32:09:33 Connected: yes
[NEW] Primary Service
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001
        00001801-0000-1000-8000-00805f9b34fb
        Generic Attribute Profile
[NEW] Characteristic
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001/char0002
        00002a05-0000-1000-8000-00805f9b34fb
        Service Changed
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001/char0002/desc0004
        00002902-0000-1000-8000-00805f9b34fb
        Client Characteristic Configuration
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c
        00000000-000e-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char000d
        00000001-000e-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char000d/desc000f
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char0010
        00000002-000e-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char0010/desc0012
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013
        00000000-0003-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013/char0014
        00000100-0001-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013/char0014/desc0016
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017
        00000000-0001-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017/char0018
        00020000-0001-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017/char0018/desc001a
而且可以通过info看到
[TILEBOX]# info
Device C0:50:27:32:09:33 (public)
        Alias: TILEBOX
        Paired: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Vendor specific           (00000000-0001-11e1-9ab4-0002a5d5c51b)
        UUID: Vendor specific           (00000000-0003-11e1-9ab4-0002a5d5c51b)
        UUID: Vendor specific           (00000000-000e-11e1-9ab4-0002a5d5c51b)
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
很可惜,这个连接不稳定,很快出现
Failed to pair: org.bluez.Error.AuthenticationFailed
[CHG] Device C0:50:27:32:09:33 Connected: no
出现这个问题后,再次连接不成功,即使重启树莓派也无效,但此时只需要重启SensorTile.Box就可以再次连接。
原因暂不明,怀疑是我手上的SensorTile.Box蓝牙不稳定造成。
8327
试试手机连接是否正常
如果出现树莓派不能连的话,手机也搜不到对应设备。但手机不会主动把蓝牙弄死,用电脑或者树莓派把蓝牙弄死以后,只要sensortile.box重启就能恢复。我最近几天从最初的hex一步步试出来的,估计我用树莓接sensortile.  详情 回复 发表于 2020-6-23 15:50
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
122
littleshrimp 发表于 2020-6-19 10:43 试试手机连接是否正常
如果出现树莓派不能连的话,手机也搜不到对应设备。但手机不会主动把蓝牙弄死,用电脑或者树莓派把蓝牙弄死以后,只要sensortile.box重启就能恢复。我最近几天从最初的hex一步步试出来的,估计我用树莓接sensortile.box只能考虑串口或者读文件了。
弄死是执行了什么操作 是不是sensortile.box处于等待连接状态 没有再次开启广播 要不你参考一下官方APP的源码看看 或者在被弄死后看一下板子上的按键试试有没有什么反应  详情 回复 发表于 2020-6-23 17:23
8327
tobot 发表于 2020-6-23 15:50
如果出现树莓派不能连的话,手机也搜不到对应设备。但手机不会主动把蓝牙弄死,用电脑或者树莓派把蓝牙弄 ...
122
嗯,正在尝试,谢谢。。。
