4958|13
关于OEMInit()中调用NandFlash总是编译不通过问题 [复制链接]
RT,项目中需要显示开机LOGO,BootLoader中显示图片过后,lanch os的时候,屏幕的图片消失,所以决定在OEMInit中添加显示LOGO函数。由于图片数据是放在flash里制定的区域的,所以说要调用flash的读写函数,来完成这个功能。我在OEMInit中直接调用BootLoader中显示图片的代码,但是编译的时候总是提示:
  1. BUILD: [01:0000010633:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_GetBlockStatus referenced in function OALFlashStoreOpen
  2. BUILD: [01:0000010634:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_GetInfo referenced in function OALFlashStoreOpen
  3. BUILD: [01:0000010635:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_Init referenced in function OALFlashStoreOpen
  4. BUILD: [01:0000010636:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_Deinit referenced in function OALFlashStoreClose
  5. BUILD: [01:0000010637:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_ReadSector referenced in function BuildLayoutInfo
  6. BUILD: [01:0000010638:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_WriteSector referenced in function OALFlashStoreWrite
  7. BUILD: [01:0000010639:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_SetBlockStatus referenced in function OALFlashStoreWrite
  8. BUILD: [01:0000010640:ERRORE] oal.lib(flashstore.obj) : error LNK2019: unresolved external symbol FMD_EraseBlock referenced in function OALFlashStoreWrite
复制代码
OALFlashStorexxxx是在C:\WINCE600\PLATFORM\TI_EVM_3530\SRC\CSP下的代码,其Source文件为:
  1. TARGETNAME=omap_boot_flashstore_lib
  2. TARGETTYPE=LIBRARY
  3. INCLUDES=$(INCLUDES);$(_PUBLICROOT)\common\oak\drivers\block\msflashfmd\inc
  4. SOURCES= \
  5.     flashStore.c
复制代码
若是在source文件中添加
$(_TARGETPLATLIB)\$(_CPUDEPPATH)\bsp_fmdnand.lib
那么编译提示找不到bsp_fmdnand.lib,已知bsp_fmdnand.lib是在编译EBOOT的时候生成的!
请大家给点建议,看能不能解决这个问题~~~
正解!谢谢Veabol,问题解决了,散分  详情 回复 发表于 2010-1-20 13:11
自己顶~~~
OAL层调用FLASH的操作可以用些IOCONTROL来操作,如果确定要用这些函数的话要改些SOURCE文件的链接库的设定,且在dir文件中使FLASH相关的文件先于OAL调用FLASH的代码之前编译。
我觉得是某些地方缺少静态链接库或者动态链接库,没有做过!友情赞助+顶贴!
to:若是在source文件中添加
查看环境变量TARGETPLATLIB的值,并确定$(_TARGETPLATLIB)\$(_CPUDEPPATH)下面有bsp_fmdnand.lib
还有编译顺序
hnyzlaojiang 该用户已被删除
提示: 作者被禁止或删除 内容自动屏蔽
在wince OAL以后文件系统已经开启,对nand的底层操作比较复杂。
最好在EBOOT的阶段OEMPlatformInit()里面做LOGO,只要在OAL里面不清屏,也一样可以用的。
引用 7 楼 skynet000 的回复:
有点奇怪的就是,我没有清屏,但是LCD黑屏......不知道怎么回事
我在DisplayInit里打印串口信息,信息也是在黑屏很长时间才显示的!也就是说wince下的现实驱动是在系统起来之后的一段时间才加载的,但是系统起来和加载驱动之间的这一段时间,LCD为什么是黑屏呢???
引用 9 楼 hao507 的回复:
把背光关了?
在oeminit中做的话,可以考虑直接读虚拟地址(把logo写在特定的flash区域中).另外,好像oeminit时,文件系统并没有开启.
帮顶下。
MARK,我也学习下、
引用 9 楼 hao507 的回复:
启动系统的时候OAL层或者其它某个地方操作了LCD的相关寄存器或者是关掉了背光。
引用 12 楼 veabol 的回复:
引用 9 楼 hao507 的回复:
