【 ST NUCLEO-H743ZI测评】+ 4、串口输出
这篇来学习下串口的使用,使用串口输出一串字符到PC机。HAL 库之前没怎么使用过,和之前的标准库还是有些区别。
一、硬件电路
使用ST-LINK虚拟串口来与PC机通信
1.1、仿真器接口
1.2、MCU接口
MCU使用的端口是PD8和PD9端口。
二、程序
2.1、main.c
int main(void)
uint8_t txdat[100]="www.eeworld.com.cn-stm32h743 usart test\r\n";
CPU_CACHE_Enable();
HAL_Init();
SystemClock_Config();
LED_Init();
KEY_Init();
UART_Init();
while (1)
led1_tog();
HAL_Delay(100);
led2_tog();
HAL_Delay(100);
led3_tog();
HAL_Delay(100);
HAL_UART_Transmit(&UartHandle, txdat, sizeof(txdat), 100);
2.2、usart.c
#include "config.h"
UART_HandleTypeDef UartHandle;
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
GPIO_InitTypeDef GPIO_InitStruct;
/*##-1- Enable peripherals and GPIO Clocks #################################*/
/* Enable GPIO TX/RX clock */
USARTx_TX_GPIO_CLK_ENABLE();
USARTx_RX_GPIO_CLK_ENABLE();
/* Enable USARTx clock */
USARTx_CLK_ENABLE();
/*##-2- Configure peripheral GPIO ##########################################*/
/* UART TX GPIO pin configuration */
GPIO_InitStruct.Pin = USARTx_TX_PIN;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = USARTx_TX_AF;
HAL_GPIO_Init(USARTx_TX_GPIO_PORT, &GPIO_InitStruct);
/* UART RX GPIO pin configuration */
GPIO_InitStruct.Pin = USARTx_RX_PIN;
GPIO_InitStruct.Alternate = USARTx_RX_AF;
HAL_GPIO_Init(USARTx_RX_GPIO_PORT, &GPIO_InitStruct);
void HAL_UART_MspDeInit(UART_HandleTypeDef *huart)
/*##-1- Reset peripherals ##################################################*/
USARTx_FORCE_RESET();
USARTx_RELEASE_RESET();
/*##-2- Disable peripherals and GPIO Clocks #################################*/
/* Configure USART3 Tx as alternate function */
HAL_GPIO_DeInit(USARTx_TX_GPIO_PORT, USARTx_TX_PIN);
/* Configure USART3 Rx as alternate function */
HAL_GPIO_DeInit(USARTx_RX_GPIO_PORT, USARTx_RX_PIN);
void UART_Init(void)
UartHandle.Instance = USART3;
UartHandle.Init.BaudRate = 115200;
UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
UartHandle.Init.StopBits = UART_STOPBITS_1;
UartHandle.Init.Parity = UART_PARITY_NONE;
UartHandle.Init.HwFlowCtl = UART_HWCONTROL_NONE;
UartHandle.Init.Mode = UART_MODE_TX_RX;
UartHandle.Init.OverSampling = UART_OVERSAMPLING_16;
UartHandle.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if(HAL_UART_DeInit(&UartHandle) != HAL_OK)
//Error_Handler();
if(HAL_UART_Init(&UartHandle) != HAL_OK)
//Error_Handler();
2.3、usart.h
#ifndef __USART_H
#define __USART_H
#define USARTx USART3
#define USARTx_CLK_ENABLE() __HAL_RCC_USART3_CLK_ENABLE()
#define USARTx_RX_GPIO_CLK_ENABLE() __HAL_RCC_GPIOD_CLK_ENABLE()
#define USARTx_TX_GPIO_CLK_ENABLE() __HAL_RCC_GPIOD_CLK_ENABLE()
#define USARTx_FORCE_RESET() __HAL_RCC_USART3_FORCE_RESET()
#define USARTx_RELEASE_RESET() __HAL_RCC_USART3_RELEASE_RESET()
/* Definition for USARTx Pins */
#define USARTx_TX_PIN GPIO_PIN_8
#define USARTx_TX_GPIO_PORT GPIOD
#define USARTx_TX_AF GPIO_AF7_USART3
#define USARTx_RX_PIN GPIO_PIN_9
#define USARTx_RX_GPIO_PORT GPIOD
#define USARTx_RX_AF GPIO_AF7_USART3
extern UART_HandleTypeDef UartHandle;
void UART_Init(void);
#endif
三、运行结果
串口间隔输出数据
