865|2
IL0389 电子纸(墨水屏)驱动 [复制链接]
项目网站
Copyright (c) 2020 Thomas Wilkinson
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
Written by Thomas Wilkinson - github.com/T-Wilko
from micropython import const
from machine import SPI, Pin
from time import sleep_ms
import ustruct
## Display resolution
EPD_WIDTH  = const(400)
EPD_HEIGHT = const(300)
# EPD_WIDTH must be divisible by 8 for this driver to work
## Display command addresses
PANEL_SETTING                       = const(0x00)
POWER_SETTING                       = const(0x01)
POWER_OFF                           = const(0x02)
POWER_OFF_SEQ_SET                   = const(0x03)
POWER_ON                            = const(0x04)
POWER_ON_MEASURE                    = const(0x05)
BOOSTER_SOFT_START_CONTROL          = const(0x06)
DEEP_SLEEP_MODE                     = const(0x07)
START_TRANSMISSION_1                = const(0x10)
DATA_STOP                           = const(0x11)
DISP_REFRESH                        = const(0x12)
START_TRANSMISSION_2                = const(0x13)
PLL_CONTROL                         = const(0x30)
TEMP_CALIBRATION                    = const(0x40)
TEMP_SENSOR_SELECTION               = const(0x41)
TEMP_SENSOR_WRITE                   = const(0x42)
TEMP_SENSOR_READ                    = const(0x43)
VCOM_DATA_INT_SETTING               = const(0x50)
LOW_POWER_DETECT                    = const(0x51)
TCON_SETTING                        = const(0x60)
RES_SETTING                         = const(0x61)
GSST_SETTING                        = const(0x65)
REVISION                            = const(0x70)
GET_STATUS                          = const(0x71)
AUTO_MEASURE_VCOM                   = const(0x80)
VCOM_READ                           = const(0x81)
VCM_DC_SETTING                      = const(0x82)
#PARTIAL_WINDOW                     = const(0x90)
PARTIAL_IN                          = const(0x91)
PARTIAL_OUT                         = const(0x92)
PROGRAM_MODE                        = const(0xA0)
ACTIVE_PROG                         = const(0xA1)
READ_OTP                            = const(0xA2)
CASCADE_SETTING                     = const(0xE0)
POWER_SAVING                        = const(0xE3)
FORCE_TEMP                          = const(0xE5)
class EPD:
    def __init__(self):
        self.spi = SPI(1, baudrate=20000000, polarity=0, phase=0, sck=Pin(18), mosi=Pin(23), miso=Pin(19))
        #self.spi = SPI(1, 10000000, sck=Pin(14), mosi=Pin(13), miso=Pin(12))
        self.spi.init()
        dc = Pin(27)
        cs = Pin(5)
        rst = Pin(14)
        busy = Pin(4)
        self.cs = cs
        self.dc = dc
        self.rst = rst
        self.busy = busy
        self.cs.init(self.cs.OUT, value=1)
        self.dc.init(self.dc.OUT, value=0)
        self.rst.init(self.rst.OUT, value=0)
        self.busy.init(self.busy.IN)
        self.width = EPD_WIDTH
        self.height = EPD_HEIGHT
        self.size = self.width * self.height // 8
        self.buf = bytearray(self.size)
    def clearBuffer(self):
        self._command(b'\x24')
        for i in range(0, len(self.buf)):
            self.buf = 255
            self._data(bytearray([self.buf]))
    def displayBuffer(self, buf):
        self._command(bytearray([START_TRANSMISSION_2]))
        for i in range(0, len(buf)):
            self._data(bytearray([buf]))
        self._command(bytearray([DATA_STOP]))
        self._command(bytearray([DISP_REFRESH]))
        self.wait_until_idle()
    def _command(self, command, data=None):
        self.cs(1) # according to LOLIN_EPD
        self.dc(0)
        self.cs(0)
        self.spi.write(command)
        self.cs(1)
        if data is not None:
            self._data(data)
    def _data(self, data):
        self.dc(1)
        self.cs(0)
        self.spi.write(data)
        self.cs(1)
    def init(self):
        #Reset EPD Driver IC
        self.reset()
        #Booster soft start
        self._command(bytearray([BOOSTER_SOFT_START_CONTROL]), b'\x17\x17\x17')
        #Power setting
        self._command(bytearray([POWER_SETTING]), b'\x03\x00\x2B\x2B\x09')
        #Power on
        self._command(bytearray([POWER_ON]))
        #Check busy pin and proceed if idle
        #Panel setting - B&W and full resolution
        self._command(bytearray([PANEL_SETTING]), b'\x1F')
        #PLL control - Set to 100Hz, default is 50Hz
        self._command(bytearray([PLL_CONTROL]), b'\x3A')
        #Resolution setting
        self._command(bytearray([RES_SETTING]), b'\x01\x90\x01\x2C')
        #VCM_DC setting - Currently set to -1V, default is -0.1V i.e. b'\x00'
        self._command(bytearray([VCM_DC_SETTING]), b'\x12')
        #VCOM and Data Interval setting
        self._command(bytearray([VCOM_DATA_INT_SETTING]), b'\x87')
    def wait_until_idle(self):
        while self.busy == 0:
            pass
        return
    def reset(self):
        self.rst(1)
        sleep_ms(1)
        self.rst(0)
        sleep_ms(10)
        self.rst(1)
    # draw the current frame memory and switch to the next memory area
    def display_frame(self):
        self._command(bytearray([DISPLAY_UPDATE_CONTROL_2]), b'\xC7')
        self._command(bytearray([MASTER_ACTIVATION]))
        self._command(bytearray([TERMINATE_FRAME_READ_WRITE]))
    # to wake call reset() or init()
    def sleep(self):
        self._command(bytearray([DEEP_SLEEP_MODE]))
86
感谢版主。代码非常漂亮。
听起来觉得很厉害,不明觉厉的那一种
