社区导航
搜索
查看: 99|回复: 0
[资料分享] TMS320V使用nof flash AM29LV400的编程实例
6444
TA的帖子
Rank: 4
发表于 2020-2-6 22:11 | 显示全部楼层 |阅读模式
代码如下
#include <csl.h>
#include <csl_pll.h>
#include <csl_emif.h>
#include <csl_chip.h>
#include <stdio.h>
#include <csl_gpio.h>
//#define AM29_FLASH_ADDR_BEGIN   (*((unsigned int *)0x200000))
#define AM29_FLASH_ADDR_BEGIN   ((unsigned int *)0x200000)
#define DATA_BUF_LEN 20
/*锁相环的设置*/
PLL_Config  myConfig      = {
  0,    //IAI: the PLL locks using the same process that was underway
                //before the idle mode was entered
  1,    //IOB: If the PLL indicates a break in the phase lock,
                //it switches to its bypass mode and restarts the PLL phase-locking
                //sequence
  6,    //PLL multiply value; multiply 12 times
  12             //Divide by 2 PLL divide value; it can be either PLL divide value
                //(when PLL is enabled), or Bypass-mode divide value
                //(PLL in bypass mode, if PLL multiply value is set to 1)
/*SDRAM的EMIF设置*/
EMIF_Config emiffig = {
  0x221,     //EGCR  : the MEMFREQ = 00,the clock for the memory is equal to cpu frequence
              //          the WPE = 0 ,forbiden the writing posting when we debug the EMIF
              //        the MEMCEN = 1,the memory clock is reflected on the CLKMEM pin
              //        the NOHOLD = 1,HOLD requests are not recognized by the EMIF
  0xFFFF,    //EMI_RST: any write to this register resets the EMIF state machine
  0x3FFF,    //CE0_1:  CE0 space control register 1
              //        MTYPE = 011,Synchronous DRAM(SDRAM),16-bit data bus width
  0xFFFF,   //CE0_2:  CE0 space control register 2
  0x00FF,   //CE0_3:  CE0 space control register 3
              //        TIMEOUT = 0xFF;
  0x1FFF,    //CE1_1:  CE0 space control register 1
            //        Asynchronous, 16Bit
  0xFFFF,    //CE1_2:  CE0 space control register 2
  0x00FF,    //CE1_3:  CE0 space control register 3
  0x1FFF,    //CE2_1:  CE0 space control register 1
  0xFFFF,    //CE2_2:  CE0 space control register 2
  0x00FF,    //CE2_3:  CE0 space control register 3
  0x1FFF,    //CE3_1:  CE0 space control register 1
  0xFFFF,    //CE3_2:  CE0 space control register 2
  0x00FF,    //CE3_3:  CE0 space control register 3
  0x2911,   //SDC1:   SDRAM control register 1
              //          TRC = 8
              //        SDSIZE = 0;SDWID = 0
              //        RFEN = 1
              //        TRCD = 2
              //        TRP  = 2
  0x0410,    //SDPER : SDRAM period register
              //          7ns *4096
  0x07FF,    //SDINIT: SDRAM initialization register
              //        any write to this register to init the all CE spaces,
              //        do it after hardware reset or power up the C55x device
  0x0131    //SDC2:      SDRAM control register 2
              //        SDACC = 0;
              //        TMRD = 01;
              //        TRAS = 0101;
              //        TACTV2ACTV = 0001;
void  delay(unsigned int d_time)
    unsigned int loop = 0;
    while(d_time--)
    loop = 1000;
    while(loop--);
Uint16    ChipErase(void)
    Uint16    i,Data;
    Uint32    TimeOut;
    *(AM29_FLASH_ADDR_BEGIN + 0x555) = 0xAA;
    *(AM29_FLASH_ADDR_BEGIN + 0x2AA) = 0x55;
    *(AM29_FLASH_ADDR_BEGIN + 0x555) = 0x80;
    *(AM29_FLASH_ADDR_BEGIN + 0x555) = 0x10;
    i = 0;
    TimeOut = 0;
    delay(8000);
    while(i<5)
        Data = *(AM29_FLASH_ADDR_BEGIN +  0x1FF);
        if    (Data == 0xFFFF)    i++;
        else    i=0;
        if ( ++TimeOut>0x1000000)    return (0);
    for    (i=0;i<0x400;i++)
        Data = *(AM29_FLASH_ADDR_BEGIN + i);
        if (Data !=0xFFFF)    return (0);
    return  (1);
Uint16    FlashWrite(Uint32    RomStart, Uint16*   buf_start,  Uint16    Length)
    Uint32    i,TimeOut;
    Uint16    Data1,Data2,j;
    for    (i=0;i<Length;i++)
            *(AM29_FLASH_ADDR_BEGIN + 0x555)= 0xAA;
            *(AM29_FLASH_ADDR_BEGIN + 0x2AA)= 0x55;
            *(AM29_FLASH_ADDR_BEGIN + 0x555) = 0xA0;
            *(AM29_FLASH_ADDR_BEGIN + RomStart + i) = *(buf_start++);
            TimeOut = 0;
            j=0;
            delay(10);
        while(j<5)
                Data1 = *(AM29_FLASH_ADDR_BEGIN + RomStart + i);
                Data2 = *(AM29_FLASH_ADDR_BEGIN + RomStart + i);
                if    (Data1 == Data2)    j++;
                else    j=0;
    return  (1);
void    FlashRead(Uint32    RomStart, Uint16*   buf_start,    Uint16    Length)
            Uint32    i;
                    *(buf_start++) =  (*((volatile    unsigned  int  *)(AM29_FLASH_ADDR_BEGIN + RomStart + i)));
main()
    Uint16 data_buf[DATA_BUF_LEN] = {0};
    unsigned int i = 0;
    Uint16 write_buf[DATA_BUF_LEN] = {0x0001,0x0002,0x0003,0x0004,0x0005,0x0006,0x0007,0x0008,0x0009,0x0000,
                                      0x0011,0x0012,0x0013,0x0014,0x0015,0x0016,0x0017,0x0018,0x0019,0x0010};
    unsigned int test_data = 0;
    /*初始化CSL库*/
    CSL_init();
    /*EMIF为全EMIF接口*/
    CHIP_RSET(XBSR,0x0a01);
    /*设置系统的运行速度为144MHz*/
    PLL_config(&myConfig);
    /*初始化DSP的EMIF*/
    EMIF_config(&emiffig);
    /*确定方向为输出*/
    GPIO_RSET(IODIR,0xFF);
    GPIO_RSET(IODATA,0x00);
    ChipErase();
    FlashWrite(0, write_buf,  DATA_BUF_LEN);
    delay(1000);
    FlashRead(0, data_buf,  DATA_BUF_LEN);
    for(i=0;i<DATA_BUF_LEN;i++)
        if(write_buf[i] != data_buf[i])
            printf("test data error:%d",i);
    if(i == DATA_BUF_LEN)
        printf("test data ok");
    for(;;);
使用道具 举报
站长推荐上一条 1/4 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-6-4 09:53 , Processed in 0.094436 second(s), 20 queries , Gzip On, MemCache On.
