2748|2
用ESP8266读取SHT3x [复制链接]
社区正在进行SHT31开发板的活动,正好在网上看到一个SHT3x(应该和SHT31兼容)的帖子,顺便就分享给大家。
原文:https://www.hackster.io/BuiHao96/control-led-and-sht3x-via-blynk-0740b9
Control Led and SHT3x via Blynk
单片机程序是使用arduino开发的
// Robo India Tutorial
// Digital Output on LED
// Hardware: NodeMCU Blynk Board
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h>
#include <Arduino.h>
#include <Wire.h>
#include "Adafruit_SHT31.h"
Adafruit_SHT31 sht31 = Adafruit_SHT31();
SimpleTimer timer;
char auth[] = "YourAuthToken";            // You should get Auth Token in the Blynk App.
char ssid[] = "YourNetworkName";    // Your WiFi credentials.
char pass[] = "YourPassword";  // Set password to "" for open networks.
void setup()
    Serial.begin(9600);// Debug console
    Blynk.begin(auth, ssid, pass);
      if (! sht31.begin(0x44))
      {   // Set to 0x45 for alternate i2c addr
    Serial.println("Couldn't find SHT31");
    while (1) delay(1);
    timer.setInterval(2000, sendUptime);
void sendUptime()
    float t = sht31.readTemperature();
    float h = sht31.readHumidity();
     //Serial.print("Temp *C = "); Serial.println(t);
     //Serial.print("Hum. % = "); Serial.println(h);
    Blynk.virtualWrite(V0, t);
    Blynk.virtualWrite(V1, h);
void loop()
  Blynk.run();
  timer.run();
效果如何?   详情 回复 发表于 2020-1-1 09:13
267
效果如何?
没有板子不能试,发出来给大家参考一下  详情 回复 发表于 2020-1-1 12:26
gitee/casy
没有板子不能试,发出来给大家参考一下
