1019|1
6943
adc12单通道多次转换例程(msp430f5529) [复制链接]
#include < msp430f5529.h>
#define NUM_OF_RESULT   8;
volatile unsigned int results[NUM_OF_RESULT];      //开辟8个16位内存空间
void main(void)
  WDTCL = WDTPW + WDTHOLD;
  P6SEL |=BIT0;
  ADC12CTL0 = ADC12ON + ADC12SHT0_8 + ADC12MSC;       //打开adc12,设置采样间隔,设置多次采样转换
  ADC12CTL1 = ADC12SHP + ADC12CONSEQ_2;                 //设置采样定时器作为采样触发信号,采样模式为单通道多次转化
  ADC12IE = BIT0;
  ADC12CTL0 |= ADC12ENC;                                //使能转换
  ADC12CTL0 |= ADC12SC;                                 //启动转换
  __bits_SR_register(LPM4_bits + GIE);
#progma vector = ADC12_VECTOR;
__interrupt void ADC12ISR (void)
  static unsigned char index = 0;
  switch(__even_in_range(ADC12IV,34))
  case 0: break;
  case 2: break;
  case 4: break;
  case 6:
    result[index] = ADC12MEM0;          //读取转换结果
    index++;
    if(index==8)
      index = 0;
  case 8: break;
  case 10: break;
  default: break;
3320
好分享,谢谢
