社区导航
搜索
查看: 270|回复: 1
[讨论] MicroPython的uos文档中增加关于 littlefs 的说明
TA的帖子
Rank: 6Rank: 6
测评达人
发表于 2019-12-4 21:33 | 显示全部楼层 |阅读模式
uos的文档中增加关于 littlefs 的说明:
Create a filesystem object that uses the FAT filesystem format. Storage of the FAT filesystem is provided by block_dev. Objects created by this constructor can be mounted using :func:`mount`.
.. staticmethod:: mkfs(block_dev)
Build a FAT filesystem on *block_dev*.
Create a filesystem object that uses the littlefs v1 filesystem format. Storage of the littlefs filesystem is provided by block_dev, which must support the :ref:`extended interface <block-device-interface>`. Objects created by this constructor can be mounted using :func:`mount`.
See :ref:`filesystem` for more information.
Build a Lfs1 filesystem on *block_dev*.
Create a filesystem object that uses the littlefs v2 filesystem format. Storage of the littlefs filesystem is provided by block_dev, which must support the :ref:`extended interface <block-device-interface>`. Objects created by this constructor can be mounted using :func:`mount`.
Build a Lfs2 filesystem on *block_dev*.
使用道具 举报
TA的帖子
Rank: 6Rank: 6
测评达人
 楼主| 发表于 2019-12-4 21:38 | 显示全部楼层
看起来 micropython 2.0中就会启用 littleFS了,有希望解决 pybflash磁盘丢失数据的问题了。
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-30 16:42 , Processed in 0.113292 second(s), 20 queries , Gzip On, MemCache On.
