TI DM8127(1GHz)的高性能集成平台。
Aptina公司的10M MT9J003 CMOS传感器。
H.264/MJPEG/MPEG4视频压缩和三流。
最高分辨率:3648×2752
最小。最低照度:0.2勒克斯F 1.2(彩色)
最小。最低照度:0.1 LUX F 1.2(B / W)
HDMI支持
千兆以太网的支持
支持POE。
支持运动检测。
支持SD卡报警和预定记录。
支持USB接口,基本的网络设置。
SPECIFICATIONS
VIDEO
Platform:TI TMS320DM8127(1GHz)
Sensor:Aptina 10M MT9J003 CMOS sensor
Highest resolution:3648X2752
Lens:C mount
Iris type:DC-Auto or Manual
AWB range:2500~7000K
AES:1/30~4000
Min illumination
Color:0.2lux@F1.4
B/W:0.1 lux@ F1.4
IR sensitivity:400~650nm
2D/3D Noise Filer
Network
Gigabit MAC built-in
Interface:Ethernet(RJ-45 10/100/1000base-TX)
Protocols:TCP/IP,DHCP,HTTP,UDP,UpnP,FTP,SMTP,RTP
Software
Mutimedia codec are compiant with xDM interface
OS is Linux and drivers are compatible with GIT
Connectors
HDMI connector
USB min-B receptacle
TI RS-485 XCVR solution
Extemal A larm/Event terminals
SD memory card receptacle
BNC connector for composite video
Reset:factory default
Video
High speed shutter:1/4000
Configuration:Brightness,Contrast,AWB,Sharpness,Saturation,Gain
Motion Detection:5 levels
Comperession:H.264/MPEG4/MJPEG
Resolution:
1.H.264HP 60fps 1080p encode+H.264 HP 30fps D1 encode+MJPEG 5fps 1080p encode+AACLC encode+A/V sync+Motion Detect+Face Detect 30fps QVGA
2.H.264HP 24fps 5MP encode+H.264 HP 30fps D1 encode+MJPEG 5fps 1080p encode+AACLC encode+A/V sync+Motion Detect+Face Detect 30fps QVGA
3.H.264HP 10fps 10MP encode +H.264 HP 30fps D1 encode+MJPEG 5fps 1080p encode+AACLC encode+A/V sync+Motion Detect+Face Detect 30fps QVGA
4.H.264HP 60fps 1080p encode +H.264 HP 30fps D1 encode+MJPEG 5fps 1080p encode+AACLC encode+A/V sync+Motion Detect+Face Detect 30fps QVGA
Audio
Microphone input
Speaker output to 3.5mm jack
Others
Power requirement:DC 12V(AC 110V PoE)
Operation Temperature:0℃~50℃
Dimension:60(W)x45(H)x87(L)mm
Accessories:Power adapter x 1
RS-232 wire x 1
Ethernet wire x 1
