Pin(av):额定输入功率. fac(min):交流最小频率(40-75Hz) 输入电容:Cin=0.3Pin(av)/fac(min)*Vin(min)*V²ripple(p-p) 功率电阻:Rsc=Vsc(max)/Ipk 输出电容:Cout=Iout(max)*(1-Dmin)/f*Vripple(pk-pk) 库仑定律:I=V*C/△T=>V=I*△T/C 波行周期:Ts=1/f 频率:f=1/Ts 占空比:D=ton/Ts 储能电感:L=Eout*toff/0.25*Iout; L=(Vin(max)-Vo)*Ton/1.4*Io(min); L=AL*N²; EL=LI² 磁感应强度增量: △B=V*D/N*Ae*f 反激匝比:n=Ns/Np=(Vo+Vd/Vs(min))*Ts/ton(max) 反激输出功率:Po=1/2*Lp*Ipk²*f 输入峰值电流:Ipk=2Po/Vs*Dmax 反激原边电感量:Lp=Vs(min)*Dmax*Ts/Ipk 反激原边匝数:Np=Lp*Ipk/△B*Ae [Lp-原边电感量﹑] 反激副边匝数:Ns=(Vo+Vd)*(1-Dmax)*Np/Vs(min)*Dmax [Vd-输出二极管压降﹑Dmax-占空比﹐Vs(min)-输入最低电压] 正激原边电流:Ic=Pi/Dmax*Vs(min) 正激原边有效值电流:Ip=Pin/Vs(min)*0.71 导线直径:Dwp=1/Rp√4sp/π( Sp=Ip/j(mm²); Is=Io/1.414; Ss=Is/j) 单管正激原边匝数:Np=Vs(max)*ton/△B*Ae; △Bmax=△Bac*Vs(max)/Vs 正激匝比:n=Ns/Np=(Vo+Vd/Vs(min))*toff/ton 单管正激副边匝数: Ns=Vo*Np*Ts/Vs(min)*ton 双管正激副边匝数: Np=Vs(max)*ton/△B*Ae; △Bmax=△Bac*Vs(max)/Vs 双管正激副边匝数:Ns=1.1(Vout+Vfwd)/Np*Vin(min)*Dmax(0.95); 推挽式输出电压:Vo=(Vs*ton/(ton+toff))*(Ns/Np) 推挽式原边匝数:Np=Vs(min)*N/V; N/V=ton/△B*Ae=ton/φ 推挽式,半桥,全桥式匝比:n=Ns/Np=(2(Vo+Vdf)/Vs(min))*Ts/ton(max) 半桥,全桥式输出电压:Vo=(1/2*Vs*2D)/2n=Vs*ton*Ns/Np*2Ts 半桥,全桥式原边匝数: Np=Vs(max)*ton/△B*Ae; △Bmax=△Bac*Vs(max)/Vs 电感电流连续时需要的电感量:L=Vo*toff/2*Io(min) 电感电流断续时需要的电感量:L=(vi-vo)*ton/0.2*Io=5(vi-vo)*vo/vi*Io*f 正激类和Buck电流连续时需要的电感量:L≧Vo*toff/△I; 断续时: L≦Vo*toff/△I Boot,Buck/Boot电感电流连续时需要的电感量:L≧Vi*ton/△I; 断续时: :L≦Vi*ton/△I 通常Ipk值算法还有:Ipk=K*Po/Vin(min): 反激:K=5.5; 正激,半桥:K=2.8; 推挽,全桥:K=1.4
