社区导航
搜索
查看: 428|回复: 4
[原创] IKS01A3驱动移植,STM32G474RE的LPS22HH气压温度检测
6393
TA的帖子
Rank: 6Rank: 6
发表于 2019-8-29 20:11 | 显示全部楼层 |阅读模式
测量LPS22HH气压和温湿度通过串口打印
/* Includes ------------------------------------------------------------------*/
#include "lps22hh_reg.h"
#include "main.h"
#include <string.h>
#include <stdio.h>
//#define MKI109V2
#define NUCLEO_G474RE
#define TX_BUF_DIM          1000
/* Private variables ---------------------------------------------------------*/
static axis1bit32_t data_raw_pressure;
static axis1bit16_t data_raw_temperature;
static float pressure_hPa;
static float temperature_degC;
static uint8_t whoamI, rst;
static uint8_t tx_buffer[TX_BUF_DIM];
extern I2C_HandleTypeDef hi2c1;
extern UART_HandleTypeDef hlpuart1;
/* Extern variables ----------------------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
 *   Replace the functions "platform_write" and "platform_read" with your
 *   platform specific read and write function.
 *   This example use an STM32 evaluation board and CubeMX tool.
 *   In this case the "*handle" variable is usefull in order to select the
 *   correct interface but the usage uf "*handle" is not mandatory.
static int32_t platform_write(void *handle, uint8_t Reg, uint8_t *Bufp,
                              uint16_t len)
  if (handle == &hi2c1)
    HAL_I2C_Mem_Write(handle, LPS22HH_I2C_ADD_H, Reg,
                      I2C_MEMADD_SIZE_8BIT, Bufp, len, 1000);
#ifdef MKI109V2
  else if (handle == &hspi2)
    HAL_GPIO_WritePin(CS_SPI2_GPIO_Port, CS_SPI2_Pin, GPIO_PIN_RESET);
    HAL_SPI_Transmit(handle, &Reg, 1, 1000);
    HAL_SPI_Transmit(handle, Bufp, len, 1000);
    HAL_GPIO_WritePin(CS_SPI2_GPIO_Port, CS_SPI2_Pin, GPIO_PIN_SET);
  else if (handle == &hspi1)
    HAL_GPIO_WritePin(CS_SPI1_GPIO_Port, CS_SPI1_Pin, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(CS_SPI1_GPIO_Port, CS_SPI1_Pin, GPIO_PIN_SET);
#endif
  return 0;
static int32_t platform_read(void *handle, uint8_t Reg, uint8_t *Bufp,
                             uint16_t len)
      HAL_I2C_Mem_Read(handle, LPS22HH_I2C_ADD_H, Reg,
#ifdef MKI109V2
    Reg |= 0x80;
    HAL_GPIO_WritePin(CS_DEV_GPIO_Port, CS_DEV_Pin, GPIO_PIN_RESET);
    HAL_SPI_Receive(handle, Bufp, len, 1000);
    HAL_GPIO_WritePin(CS_DEV_GPIO_Port, CS_DEV_Pin, GPIO_PIN_SET);
  else
    Reg |= 0x80;
    HAL_GPIO_WritePin(CS_RF_GPIO_Port, CS_RF_Pin, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(CS_RF_GPIO_Port, CS_RF_Pin, GPIO_PIN_SET);
#endif
  return 0;
 *  Function to print messages
void tx_com( uint8_t *tx_buffer, uint16_t len )
  #ifdef NUCLEO_G474RE
  HAL_UART_Transmit( &hlpuart1, tx_buffer, len, 1000 );
  #endif
  #ifdef MKI109V2
  CDC_Transmit_FS( tx_buffer, len );
  #endif
/* Main Example --------------------------------------------------------------*/
void example_main(void)
   *  Initialize mems driver interface
  lps22hh_ctx_t dev_ctx;
  dev_ctx.write_reg = platform_write;
  dev_ctx.read_reg = platform_read;
  dev_ctx.handle = &hi2c1;
   *  Check device ID
  whoamI = 0;
  lps22hh_device_id_get(&dev_ctx, &whoamI);
  if ( whoamI != LPS22HH_ID )
    while(1); /*manage here device not found */
   *  Restore default configuration
  lps22hh_reset_set(&dev_ctx, PROPERTY_ENABLE);
  do {
    lps22hh_reset_get(&dev_ctx, &rst);
  } while (rst);
   *  Enable Block Data Update
  lps22hh_block_data_update_set(&dev_ctx, PROPERTY_ENABLE);
   * Set Output Data Rate
  lps22hh_data_rate_set(&dev_ctx, LPS22HH_10_Hz_LOW_NOISE);
   * Read samples in polling mode (no int)
  while(1)
     * Read output only if new value is available
    lps22hh_reg_t reg;
    lps22hh_read_reg(&dev_ctx, LPS22HH_STATUS, (uint8_t *)®, 1);
    if (reg.status.p_da)
      memset(data_raw_pressure.u8bit, 0x00, sizeof(int32_t));
      lps22hh_pressure_raw_get(&dev_ctx, data_raw_pressure.u8bit);
      pressure_hPa = lps22hh_from_lsb_to_hpa( data_raw_pressure.i32bit);
      sprintf((char*)tx_buffer, "pressure [hPa]:%6.2f\r\n", pressure_hPa);
      tx_com( tx_buffer, strlen( (char const*)tx_buffer ) );
    if (reg.status.t_da)
      memset(data_raw_temperature.u8bit, 0x00, sizeof(int16_t));
      lps22hh_temperature_raw_get(&dev_ctx, data_raw_temperature.u8bit);
      temperature_degC = lps22hh_from_lsb_to_celsius( data_raw_temperature.i16bit );
      sprintf((char*)tx_buffer, "temperature [degC]:%6.2f\r\n", temperature_degC );
工程文件:
stm32g474 lps22hh.rar (2.57 MB, 下载次数: 3)
虾扯蛋
使用道具 举报
8587
TA的帖子
Rank: 6Rank: 6
测评达人
发表于 2019-8-29 21:45 | 显示全部楼层
这不算驱动移植吧
应该叫什么?  详情 回复 发表于 2019-8-29 22:01
使用道具 举报
6393
TA的帖子
Rank: 6Rank: 6
 楼主| 发表于 2019-8-29 22:01 来自手机 | 显示全部楼层
dcexpert 发表于 2019-8-29 21:45 这不算驱动移植吧
应该叫什么?
使用道具 举报
8587
TA的帖子
Rank: 6Rank: 6
测评达人
发表于 2019-8-29 22:57 | 显示全部楼层
感觉是在STM32G474RE上使用传感器,而没有涉及到传感器的驱动移植
这个工程里的LPS22HH的驱动是是官方提供的 驱动提供一个读取数据通过串口发送的DEMO 是应用在NUCLEO_STM32F411RE开发板上的 没有提供项目文件 改这个东西是为了方便网友(拿用主义)在G474平台上使用这  详情 回复 发表于 2019-8-30 21:56
使用道具 举报
6393
TA的帖子
Rank: 6Rank: 6
 楼主| 发表于 2019-8-30 21:56 | 显示全部楼层
dcexpert 发表于 2019-8-29 22:57 感觉是在STM32G474RE上使用传感器,而没有涉及到传感器的驱动移植
没有提供项目文件
改这个东西是为了方便网友(拿用主义)在G474平台上使用这款传感器
因为ST将驱动都已经封装好
应用在G474或者其它单片机只需要配置好对应单片机的I2C和UART
再对代码做简单修改就可以在对应的单片机上使用
方便了很多
虾扯蛋
使用道具 举报
站长推荐上一条 /6 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-9-21 15:32 , Processed in 0.176873 second(s), 18 queries , Gzip On, MemCache On.
