社区导航
搜索
查看: 602|回复: 5
[分享] DSP28335 pwm程序死区实验
1158
TA的帖子
Rank: 2
发表于 2019-8-17 21:03 | 显示全部楼层 |阅读模式
main函数:
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
Uint16    *ExRamStart = (Uint16 *)0x100000;
void EPwmSetup();
Uint16  i;
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
   InitXintf16Gpio();    //zq
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
   InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
// Step 4. Initialize the Device Peripheral. This function can be
//         found in DSP2833x_CpuTimers.c
  // InitCpuTimers();   // For this example, only initialize the Cpu Timers
// Configure CPU-Timer 0, 1, and 2 to interrupt every second:
// 150MHz CPU Freq, 1 second Period (in uSeconds)
   //ConfigCpuTimer(&CpuTimer0, 150, 1000000);
   //ConfigCpuTimer(&CpuTimer1, 150, 1000000);
   //ConfigCpuTimer(&CpuTimer2, 150, 1000000);
//    StartCpuTimer0();
    EPwmSetup();
    for(; ;)
// No more.
// TI File $Revision: /main/9 $
// Checkin $Date: August 10, 2007   09:05:08 $
// FILE:    Example_EpwmSetup.c
// TITLE:    Frequency measurement using EQEP peripheral
// DESCRIPTION:
// This file contains source for the ePWM initialization for the
// freq calculation module
// Original Author: SD
// $TI Release: DSP2833x Header Files V1.01 $
// $Release Date: September 26, 2007 $
EPWM配置函数
#define CPU_CLK   150e6
#define PWM_CLK   20e3                // If diff freq. desired, change freq here.
#define SP        CPU_CLK/(2*PWM_CLK)
#define TBCTLVAL  0x200E              // Up-down cnt, timebase = SYSCLKOUT
void EPwmSetup()
    InitEPwm1Gpio();
    EPwm1Regs.TBSTS.all=0;
    EPwm1Regs.TBPHS.half.TBPHS=0;
    EPwm1Regs.TBCTR=0;
    EPwm1Regs.CMPCTL.all=0x50;        // Immediate mode for CMPA and CMPB
    EPwm1Regs.CMPA.half.CMPA =SP/2;
    EPwm1Regs.CMPB=0;
    EPwm1Regs.AQCTLA.all=0x60;        // EPWMxA = 1 when CTR=CMPA and counter inc
                                      // EPWMxA = 0 when CTR=CMPA and counter dec
    EPwm1Regs.AQCTLB.all=0;
    EPwm1Regs.AQSFRC.all=0;
    EPwm1Regs.AQCSFRC.all=0;
    EPwm1Regs.DBCTL.all=0xb;          // EPWMxB is inverted
    EPwm1Regs.DBRED=500;(死区设置)
    EPwm1Regs.DBFED=500;(死区设置)
    EPwm1Regs.TZSEL.all=0;
    EPwm1Regs.TZCTL.all=0;
    EPwm1Regs.TZEINT.all=0;
    EPwm1Regs.TZFLG.all=0;
    EPwm1Regs.TZCLR.all=0;
    EPwm1Regs.TZFRC.all=0;
    EPwm1Regs.ETSEL.all=0;            // Interrupt when TBCTR = 0x0000
    EPwm1Regs.ETFLG.all=0;
    EPwm1Regs.ETCLR.all=0;
    EPwm1Regs.ETFRC.all=0;
    EPwm1Regs.PCCTL.all=0;
    EPwm1Regs.TBCTL.all=0x0010+TBCTLVAL;            // Enable Timer
    EPwm1Regs.TBPRD=SP;
来源:EEWorld DSP 与 ARM 处理器板块,转载请附上链接
使用道具 举报
1434
TA的帖子
Rank: 4
发表于 2019-8-19 07:54 | 显示全部楼层
能给点儿介绍说明就好啦
使用道具 举报
TA的帖子
Rank: 1
发表于 2019-8-21 16:01 | 显示全部楼层
感谢分享
多多支持  详情 回复 发表于 2019-8-22 17:11
使用道具 举报
1158
TA的帖子
Rank: 2
 楼主| 发表于 2019-8-22 17:11 | 显示全部楼层
使用道具 举报
TA的帖子
Rank: 1
发表于 2019-8-23 09:57 | 显示全部楼层
波形漂亮 (进芯国产28335 )
使用道具 举报
280
TA的帖子
Rank: 3Rank: 3
发表于 2019-8-24 09:14 | 显示全部楼层
感谢分享,加点讲解就更好了
使用道具 举报
站长推荐上一条 /6 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-9-20 05:42 , Processed in 0.205159 second(s), 18 queries , Gzip On, MemCache On.
