社区导航
搜索
查看: 455|回复: 7
[求助] 28335为啥不能4路PWM同时输出
TA的帖子
Rank: 2
发表于 2019-7-30 14:37 | 显示全部楼层 |阅读模式
#include"DSP28x_Project.h"
#define CPU_CLK 150e6   //系统时钟150MHz
#define TBCTLVAL 0x200E     //控制寄存器的值
Uint32 PWM_CLK,PWM_CLK1,PWM_CLK2;
float SP,SP1,SP2;
void main(void)
    InitSysCtrl();   //初始化系统
    InitGpio();     //初始化GPIIO
    InitPieCtrl();  //清除所有中断
    IER = 0x0000;
    IFR = 0x0000;
    InitPieVectTable();  //初始化中断向量表
    PWM_CLK1 = 1000;
    SP1 = CPU_CLK/(2*PWM_CLK1);
    InitEPwm1Gpio();
    EPwm1Regs.TBSTS.all = 0;   //将时基的状态寄存器清零
    EPwm1Regs.TBPHS.half.TBPHS = 0;  //相位寄存器设置为0
    EPwm1Regs.TBCTR = 0;   //时基计数器清零
    EPwm1Regs.CMPCTL.all = 0x50;  //CMPA和CMPB配置为立即模式
    EPwm1Regs.CMPA.half.CMPA = SP1/2;  //设置占空比为0.5,SP是周期寄存器的值
    EPwm1Regs.CMPB = 0;
    EPwm1Regs.AQCTLA.all = 0x60;   //当时间基准计数器的值等于CMPA的值,且正在递增计数,EPWMxA输出高电平;当时间基准计数器的值等于CMPA的值,且正在递减计数,EPWMxA输出低电平
    EPwm1Regs.AQCTLB.all = 0;
    EPwm1Regs.AQSFRC.all = 0;
    EPwm1Regs.AQCSFRC.all = 0;
    EPwm1Regs.DBCTL.all = 0xb;    //EPwm1B与EPwm1A相关联,即EPwm1B随着EPwm1A的变化而变化
    EPwm1Regs.DBRED = 0;          //上升沿的死区时间设置为0
    EPwm1Regs.DBFED = 0;          //下降沿的死区时间设置为0
    EPwm1Regs.TZSEL.all = 0;      //没有用到联防区模块,全部失效
    EPwm1Regs.TZCTL.all = 0;
    EPwm1Regs.TZEINT.all = 0;
    EPwm1Regs.TZFLG.all = 0;
    EPwm1Regs.TZCLR.all = 0;
    EPwm1Regs.TZFRC.all = 0;
    EPwm1Regs.ETSEL.all = 0;
    EPwm1Regs.ETFLG.all = 0;
    EPwm1Regs.ETCLR.all = 0;
    EPwm1Regs.ETFRC.all = 0;
    EPwm1Regs.PCCTL.all = 0;
    EPwm1Regs.TBCTL.all = 0x0010 + TBCTLVAL;    //增减模式
    EPwm1Regs.TBPRD = SP1;
    PWM_CLK2 = 2000;
    SP2 = CPU_CLK/(2*PWM_CLK2);
    InitEPwm2Gpio();
    EPwm2Regs.TBSTS.all = 0;   //将时基的状态寄存器清零
    EPwm2Regs.TBPHS.half.TBPHS = 0;  //相位寄存器设置为0
    EPwm2Regs.TBCTR = 0;   //时基计数器清零
    EPwm2Regs.CMPCTL.all = 0x50;  //CMPA和CMPB配置为立即模式
    EPwm2Regs.CMPA.half.CMPA = SP2/2;  //设置占空比为0.5,SP是周期寄存器的值
    EPwm2Regs.CMPB = 0;
    EPwm2Regs.AQCTLA.all = 0x60;   //当时间基准计数器的值等于CMPA的值,且正在递增计数,EPWMxA输出高电平;当时间基准计数器的值等于CMPA的值,且正在递减计数,EPWMxA输出低电平
    EPwm2Regs.AQCTLB.all = 0;
    EPwm2Regs.AQSFRC.all = 0;
    EPwm2Regs.AQCSFRC.all = 0;
    EPwm2Regs.DBCTL.all = 0xb;    //EPwm1B与EPwm1A相关联,即EPwm1B随着EPwm1A的变化而变化
    EPwm2Regs.DBRED = 0;          //上升沿的死区时间设置为0
    EPwm2Regs.DBFED = 0;          //下降沿的死区时间设置为0
    EPwm2Regs.TZSEL.all = 0;      //没有用到联防区模块,全部失效
    EPwm2Regs.TZCTL.all = 0;
    EPwm2Regs.TZEINT.all = 0;
    EPwm2Regs.TZFLG.all = 0;
    EPwm2Regs.TZCLR.all = 0;
    EPwm2Regs.TZFRC.all = 0;
    EPwm2Regs.ETSEL.all = 0;
    EPwm2Regs.ETFLG.all = 0;
    EPwm2Regs.ETCLR.all = 0;
    EPwm2Regs.ETFRC.all = 0;
    EPwm2Regs.PCCTL.all = 0;
    EPwm2Regs.TBCTL.all = 0x0010 + TBCTLVAL;    //增减模式
    EPwm2Regs.TBPRD = SP2;
    for(; ;)
//看了示波器,只有输出2000Hz的波形,1000Hz的为啥没有??哪里写错了,请指教,小白一枚。
来源:EEWorld 微控制器 MCU板块,转载请附上链接
使用道具 举报
2449
TA的帖子
Rank: 4
发表于 2019-7-30 15:12 | 显示全部楼层
好好检查程序,一定可以做到的
为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2019-7-30 15:22 | 显示全部楼层
chenbingjy 发表于 2019-7-30 15:12 好好检查程序,一定可以做到的
每个pwm波的配置都一样的,只是改变了频率和周期值。单个PWM编译都能成功。。
不明白你说的"单个PWM编译都能成功"是什么意思? 单个都能产生波形吗?  详情 回复 发表于 2019-7-30 15:36
使用道具 举报
2449
TA的帖子
Rank: 4
发表于 2019-7-30 15:36 | 显示全部楼层
我将变成怎样 发表于 2019-7-30 15:22 每个pwm波的配置都一样的,只是改变了频率和周期值。单个PWM编译都能成功。。
单个都能产生波形吗?
确定管脚都不一样吧
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2019-7-30 15:46 | 显示全部楼层
chenbingjy 发表于 2019-7-30 15:36 我将变成怎样 发表于 2019-7-30 15:22 每个pwm波的配置都一样的,只是改变了频率和周期值。单个PWM编译都 ...
4个管脚,只有两个有互补波形。PWM1与PWM2分开编译,对应的两个GPIO口都有波形。程序合在一起编译(如上图的程序),PWM2对应的两个GPIO口有波形,PWM1的没有。
使用道具 举报
2449
TA的帖子
Rank: 4
发表于 2019-7-30 15:51 | 显示全部楼层
 InitEPwm2Gpio();
感觉很奇怪。会不会是你 InitEPwm2Gpio();把 InitEPwm1Gpio();里的给覆盖掉啦。
贴出代码。
使用道具 举报
TA的帖子
Rank: 2
 楼主| 发表于 2019-7-30 15:58 | 显示全部楼层
chenbingjy 发表于 2019-7-30 15:51  InitEPwm2Gpio(); 感觉很奇怪。会不会是你 InitEPwm2Gpio();把 InitEPwm1Gpio();里的给 ...
void
InitEPwm1Gpio(void)
    EALLOW;
    // Enable internal pull-up for the selected pins
    // Pull-ups can be enabled or disabled by the user.
    // This will enable the pullups for the specified pins.
    // Comment out other unwanted lines.
    GpioCtrlRegs.GPAPUD.bit.GPIO0 = 0;    // Enable pull-up on GPIO0 (EPWM1A)
    GpioCtrlRegs.GPAPUD.bit.GPIO1 = 0;    // Enable pull-up on GPIO1 (EPWM1B)
    // Configure ePWM-1 pins using GPIO regs
    // This specifies which of the possible GPIO pins will be ePWM1 functional
    // pins. Comment out other unwanted lines.
    GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1;   // Configure GPIO0 as EPWM1A
    GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1;   // Configure GPIO1 as EPWM1B
    EDIS;
void
InitEPwm2Gpio(void)
    EALLOW;
    GpioCtrlRegs.GPAPUD.bit.GPIO2 = 0;    // Enable pull-up on GPIO2 (EPWM2A)
    GpioCtrlRegs.GPAPUD.bit.GPIO3 = 0;    // Enable pull-up on GPIO3 (EPWM3B)
    // Configure ePWM-2 pins using GPIO regs
    // This specifies which of the possible GPIO pins will be ePWM2 functional
    GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1;   // Configure GPIO2 as EPWM2A
    GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 1;   // Configure GPIO3 as EPWM2B
    EDIS;
//文件里配置的,没改过。
使用道具 举报
1356
TA的帖子
Rank: 4
发表于 2019-7-31 08:15 | 显示全部楼层
慢慢查吧,还得结合内核里面的基础单元。
使用道具 举报
站长推荐上一条 /3 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-8-22 23:19 , Processed in 0.246004 second(s), 17 queries , Gzip On, MemCache On.
