社区导航
搜索
查看: 1123|回复: 5
[求助] stm32f103无刷直流电机控制程序
TA的帖子
Rank: 1
发表于 2019-7-9 22:13 | 显示全部楼层 |阅读模式
小弟最近在做无刷直流电机控制方面的东西,写代码时遇到了不少问题,老进不去中断程序,不能实现换相问题,哪位大佬做过能交流一下嘛
使用道具 举报
TA的帖子
133
管理员
Rank: 13Rank: 13Rank: 13Rank: 13
发表于 2019-7-10 04:51 | 显示全部楼层
具体问题具体分析,你可以把你遇到的具体问题情况发帖说明一下,坛子里的热心网友会帮忙解答的
玩板看这里:
http://bbs.eeworld.com.cn/elecplay.html
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2019-7-10 08:53 | 显示全部楼层
okhxyyo 发表于 2019-7-10 04:51 具体问题具体分析,你可以把你遇到的具体问题情况发帖说明一下,坛子里的热心网友会帮忙解答的
定时器1的配置
unsigned short int  CCR1_Val = 0;
unsigned short int  CCR2_Val = 0;
unsigned short int  CCR3_Val = 0;
volatile unsigned char  HALL_Value = 0;
//unsigned char HALL_flag =1;
* ????: Timer1_Init();
* ????: ???1???
* ????: void
void PWM_GPIO_Init(void)
       GPIO_InitTypeDef GPIO_InitStructure;
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); // ??GPIOA/GPIOB??
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;    //PWM???PA8,9,10
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                     //??????
     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
     GPIO_Init(GPIOA,&GPIO_InitStructure);                               //???GPIO
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;  //PWM???PA7
     GPIO_Init(GPIOB,&GPIO_InitStructure);                               //???GPIO
* ????: HALL_GPIO_Init();
* ????: void
void HALL_GPIO_Init(void)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);    // ??GPIOC??
     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;  //PWM???PA7
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;                     //??????
     GPIO_Init(GPIOB, &GPIO_InitStructure);
* ????: ???1???
* ????: void
void Timer1_Init(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        PWM_GPIO_Init(); //?????
        HALL_GPIO_Init();
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);   // ?????1???
               // ??20KHZ
              //??3?PWM???
        CCR1_Val    = 2799;
        CCR2_Val    = 2799;
        CCR3_Val    = 2799;
        TIM_TimeBaseInitStructure.TIM_Prescaler = 0;                    // 72MHZ
        TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; // ??????
        TIM_TimeBaseInitStructure.TIM_Period = 7199;         // ????????????
        TIM_TimeBaseInitStructure.TIM_ClockDivision = 0;                // ??????--???
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
        //PWM????-CH1
        TIM_OCInitStructure.TIM_OCMode      = TIM_OCMode_PWM1;          //PWM??
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;  //????
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;//???????
        TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //?????
        TIM_OCInitStructure.TIM_OCPolarity   =  TIM_OCPolarity_High;        //??????
        TIM_OCInitStructure.TIM_OCNPolarity  =  TIM_OCNPolarity_High; //?????????
        TIM_OCInitStructure.TIM_OCIdleState  =  TIM_OCIdleState_Set;  //???????
        TIM_OCInitStructure.TIM_OCNIdleState =  TIM_OCNIdleState_Set; //??????????
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_Pulse = CCR2_Val ;
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_Pulse = CCR3_Val ;
        TIM_OC3Init(TIM1, &TIM_OCInitStructure);
        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;//?????????
        TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;//?????????
        TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;   //????
        TIM_BDTRInitStructure.TIM_DeadTime = 0xAC;                 //????--2us
        TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;        //??????
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;//??????
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;//??????
        TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
        TIM_CCPreloadControl(TIM1, ENABLE);     //?????
//        TIM_ITConfig(TIM1, TIM_IT_COM, ENABLE); //??????
        TIM_Cmd(TIM1, ENABLE);
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
       TIM_CCxCmd(TIM1,TIM_Channel_1,TIM_CCx_Disable);
       TIM_CCxNCmd(TIM1,TIM_Channel_1,TIM_CCxN_Disable);
       TIM_CCxCmd(TIM1,TIM_Channel_2,TIM_CCx_Disable);
       TIM_CCxNCmd(TIM1,TIM_Channel_2,TIM_CCxN_Disable);
       TIM_CCxCmd(TIM1,TIM_Channel_3,TIM_CCx_Disable);
       TIM_CCxNCmd(TIM1,TIM_Channel_3,TIM_CCxN_Disable);
* ????: BLDC_Hall_Convet();
* ????: ??????????--T1 T3 T5/T4 T6 T2??
void BLDC_Hall_Convet(void)
// char PB0_Value,PB1_Value,PA1_Value;
//    PB0_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0);
//    PB1_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1)*2;
//    PA1_Value = GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_1)*4;
//   HALL_Value = PB0_Value+PB1_Value+PA1_Value;
  //HALL_Value =(unsigned char)((GPIO_ReadInputData(GPIOA) & 0x0007));        //?????
  HALL_Value=GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_5)+(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)<<1)+(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7)<<2);//???????MOS???,????? hallValueTemp=GPIO_ReadInputData(GPIOA)&0X7;???HA?HB?HC??????PA0?PA1?PA2?
//  if(HALL_flag ==1) //??
     switch(HALL_Value)   //??????,??CCER???????????
       case 0x05: //?? T3/T4
            /*  Channel2 configuration */
            TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1);
            TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Enable);
            TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
            /*  Channel1 configuration */
            TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
            TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
            TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_Active);
            /*  Channel3 configuration */
            TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Disable);
            TIM_CCxNCmd(TIM1, TIM_Channel_3,TIM_CCxN_Enable);
            TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_InActive);
            break;
            case 0x04: //T4 T5
           TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_OCMode_PWM1);
           TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
           TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
           TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Disable);
           TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
           TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_InActive);
           break;
      case 0x06: //T5 T6
            TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_Active);
            TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_InActive);
            break;
            case 0x02: //T6 T1
          TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
          TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
          TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
          TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
          break;
            case 0x03: // T1 T2
          TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_Active);
          TIM_CCxNCmd(TIM1, TIM_Channel_2,TIM_CCxN_Enable);
          break;
            case 0x01: //T2 T3
           TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1 );
           break;
            default:
                            break;
外部中断配置
void GPIO_Config(void)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//ʹÄÜPORTBʱÖÓ
    GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //IO¿ÚËÙ¶ÈΪ50MHz
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //ÉèÖø¡¿ÕÊäÈëģʽ
     GPIO_Init(GPIOA, &GPIO_InitStructure);//³õʼ»¯GPIOB0,1,2
void EXTIX_Init(void)
       EXTI_InitTypeDef EXTI_InitStructure;
       NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    HALL_GPIO_Init();     //    °´¼ü¶Ë¿Ú³õʼ»¯
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);    //ʹÄܸ´Óù¦ÄÜʱÖÓ
   //GPIOA.5      ÖжÏÏßÒÔ¼°Öжϳõʼ»¯ÅäÖà  ÉÏÉýÑØ´¥·¢PA5
      GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource5);
      EXTI_InitStructure.EXTI_Line=EXTI_Line5;
      EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
      EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
      EXTI_Init(&EXTI_InitStructure);          //¸ù¾ÝEXTI_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèEXTI¼Ä´æÆ÷
   //GPIOA.6      ÖжÏÏßÒÔ¼°Öжϳõʼ»¯ÅäÖà  ÉÏÉýÑØ´¥·¢PA6
      GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource6);
      EXTI_InitStructure.EXTI_Line=EXTI_Line6;
   //GPIOA.7      ÖжÏÏßÒÔ¼°Öжϳõʼ»¯ÅäÖà ÉÏÉýÑØ´¥·¢ PA7
       GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource7);
      EXTI_InitStructure.EXTI_Line=EXTI_Line7;
      NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;              //ʹÄÜ»ô¶ûÐźÅËùÔÚµÄÍⲿÖжÏͨµÀ
      NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;    //ÇÀÕ¼ÓÅÏȼ¶2£¬
      NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;                    //×ÓÓÅÏȼ¶0
      NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                                //ʹÄÜÍⲿÖжÏͨµÀ
      NVIC_Init(&NVIC_InitStructure);
//ÍⲿÖжϷþÎñ³ÌÐò
void EXTI9_5_IRQHandler(void)
    if((EXTI_GetITStatus(EXTI_Line5) != RESET)|(EXTI_GetITStatus(EXTI_Line6) != RESET)|(EXTI_GetITStatus(EXTI_Line7) != RESET))
    BLDC_Hall_Convet();
    EXTI_ClearITPendingBit(EXTI_Line5); //Çå³ýLINE5ÉϵÄÖжϱê־λ
    EXTI_ClearITPendingBit(EXTI_Line6);  //Çå³ýLINE6ÉϵÄÖжϱê־λ
    EXTI_ClearITPendingBit(EXTI_Line7);  //Çå³ýLINE7ÉϵÄÖжϱê־λ
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2019-7-10 08:54 | 显示全部楼层
不知道问题出在哪了,哪位大佬能帮小弟看看
使用道具 举报
TA的帖子
Rank: 2
发表于 2019-12-21 11:05 | 显示全部楼层
应改成
if((EXTI_GetITStatus(EXTI_Line5) != RESET) || (EXTI_GetITStatus(EXTI_Line6) != RESET) ||(EXTI_GetITStatus(EXTI_Line7) != RESET))
你好,你是想做什么产品应用,可以聊聊么?  详情 回复 发表于 2019-12-23 10:56
使用道具 举报
164
TA的帖子
Rank: 6Rank: 6
发表于 2019-12-23 10:56 | 显示全部楼层
rat2003 发表于 2019-12-21 11:05 if((EXTI_GetITStatus(EXTI_Line5) != RESET)|(EXTI_GetITStatus(EXTI_Line6) != RESET)|(EXTI_GetITStatus ...
欢迎大家来到电机驱动控制技术天地,一起在EEworld交流、学习。
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-5-25 23:26 , Processed in 0.214850 second(s), 24 queries , Gzip On, MemCache On.
