自己弄得U-BOOT 和LINUX内核移植, 成功!!!!!!!
今天 很是高兴, 哈哈, 可以nand_flash 启动啦,, 一段没有整 , 昨天详细了解啦下命令 ,今天重新编译啦啦一下 , 哈哈,通过啦, 其实主要是相关的的参数的配置 , 现在有些了解,
“”“”“之后就是一阵洋文飘过……”“”“”“”“”“”“”哈哈真是一阵洋文
U-Boot 1.1.6 (Jun 8 2010 - 10:50:34)
DRAM: 64 MB
Flash: 512 kB
NAND: 64 MB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
NAND read: device 0 offset 262144, size 2097152 ...
2097152 bytes read: OK
## Booting image at 30007fc0 ...
Image Name: linux-2.6.30
Created: 2010-01-25 12:53:12 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1929376 Bytes = 1.8 MB
Load Address: 30007fc0
Entry Point: 30008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
Starting kernel ...
Uncompressing Linux............................................................................................................................. done, booting the kernel. Linux version 2.6.30.4 (lanyu@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #2 Mon Jan 18 09:04:48 CST 2010 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=00007177 CPU: VIVT data cache, VIVT instruction cache Machine: SMDK2410 Memory policy: ECC disabled, Data cache writeback CPU S3C2410A (id 0x32410002) S3C24XX Clocks, (c) 2004 Simtec Electronics S3C2410: core 200.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: root=1f02 init=/linuxrc console=ttySAC0,115200 devfs=mount NR_IRQS:85 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) Console: colour dummy device 80x30 console [ttySAC0] enabled Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60816KB available (3604K code, 316K data, 132K init, 0K highmem) Calibrating delay loop... 49.76 BogoMIPS (lpj=124416) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 936 bytes NET: Registered protocol family 16 S3C Power Management, Copyright 2004 Simtec Electronics S3C2410: Initialising architecture S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c2410-i2c s3c2410-i2c: slave address 0x10 s3c2410-i2c s3c2410-i2c: bus frequency set to 97 KHz s3c2410-i2c s3c2410-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 NetWinder Floating Point Emulator V0.97 (extended precision) JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. yaffs Jan 18 2010 09:01:47 Installing. msgmni has been set to 118 io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered s3c2410-lcd s3c2410-lcd: no platform data for lcd, cannot attach s3c2410-lcd: probe of s3c2410-lcd failed with error -22 lp: driver loaded but no devices found ppdev: user-space parallel port driver Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled s3c2410-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2410 s3c2410-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2410 s3c2410-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2410 brd: module loaded loop: module loaded Uniform Multi-Platform E-IDE driver ide-gd driver 1.18 ide-cd driver 5.00 Driver 'sd' needs updating - please use bus_type methods dm9000 Ethernet Driver, V1.31 S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c2410-nand s3c2410-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit) Scanning device for bad blocks Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit": 0x000000000000-0x000000100000 : "Boot" 0x000000100000-0x000000500000 : "Kernel" 0x000000500000-0x000002500000 : "Rootfs" 0x000002500000-0x000004000000 : "User" usbmon: debugfs is not available ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver libusual usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core USB Serial support registered for FTDI USB Serial Device usbcore: registered new interface driver ftdi_sio ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver mice: PS/2 mouse device common for all mice S3C24XX RTC, (c) 2004,2006 Simtec Electronics S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled Advanced Linux Sound Architecture Driver Version 1.0.20. ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. drivers/rtc/hctosys.c: unable to open rtc device (rtc0) yaffs: dev is 32505858 name is "mtdblock2" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.2, "mtdblock2" yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:2. Freeing init memory: 132K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Backtrace: [<c002d9f8>] (dump_backtrace+0x0/0x114) from [<c02dbe24>] (dump_stack+0x18/0x1c) r7:00000000 r6:00000000 r5:00000000 r4:c03d0e34 [<c02dbe0c>] (dump_stack+0x0/0x1c) from [<c02dbe74>] (panic+0x4c/0x11c) [<c02dbe28>] (panic+0x0/0x11c) from [<c0029500>] (init_post+0xd4/0xfc) r3:0000000b r2:00000008 r1:00000007 r0:c0353e03 [<c002942c>] (init_post+0x0/0xfc) from [<c0008610>] (kernel_init+0xc0/0xe8) r4:c03d0700 [<c0008550>] (kernel_init+0x0/0xe8) from [<c004cccc>] (do_exit+0x0/0x58c) r4:00000000
图片就不发啦, 继续研究 !!!!!!!!
