1924|0
HPS调用没有输入输出管脚 [复制链接]
我在用QSYS调用HPS的时候总是报错,没有输入输出管脚,也没有block diagram的显示
下面提示的错误是:
Error: hps_0: list element in quotes followed by ":" instead of space
    while executing
"llength $db"
    ("if" test expression)
    invoked from within
"if {[llength $db] != $PASSED_LIST_SIZE} {
    return 0
    (procedure "::pin_mux_db::load" line 24)
    invoked from within
"::pin_mux_db::load $device"
    invoked from within
"set load_rc [::pin_mux_db::load $device]"
    (procedure "ensure_pin_muxing_data" line 20)
    invoked from within
"ensure_pin_muxing_data $device_family"
    (procedure "validate" line 4)
    invoked from within
"validate"
    (procedure "compose" line 9)
    invoked from within
"compose"
重装软件之后仍然如此,请问有什么办法可以解决吗
此帖出自FPGA/CPLD论坛
点赞 关注(1)
