;// TI File $Revision: /main/1 $
;// Checkin $Date: August 18, 2006 13:45:55 $
;// FILE: DSP2833x_CodeStartBranch.asm
;// TITLE: Branch for redirecting code execution after boot.
;// For these examples, code_start is the first code that is executed after
;// exiting the boot ROM code.
;// The codestart section in the linker cmd file is used to physically place
;// this code at the correct memory location. This section should be placed
;// at the location the BOOT ROM will re-direct the code to. For example,
;// for boot to FLASH this code will be located at 0x3f7ff6.
;// In addition, the example DSP2833x projects are setup such that the codegen
;// entry point is also set to the code_start label. This is done by linker
;// option -e in the project build options. When the debugger loads the code,
;// it will automatically set the PC to the "entry point" address indicated by
;// the -e linker option. In this case the debugger is simply assigning the PC,
;// it is not the same as a full reset of the device.
;// The compiler may warn that the entry point for the project is other then
;// _c_init00. _c_init00 is the C environment setup and is run before
;// main() is entered. The code_start code will re-direct the execution
;// to _c_init00 and thus there is no worry and this warning can be ignored.
;// $TI Release: DSP2833x/DSP2823x C/C++ Header Files V1.31 $
;// $Release Date: August 4, 2009 $
.text
wd_disable:
SETC OBJMODE ;Set OBJMODE for 28x object code
EALLOW ;Enable EALLOW protected register access
MOVZ DP, #7029h>>6 ;Set data page for WDCR register
MOV @7029h, #0068h ;Set WDDIS bit in WDCR to disable WD
EDIS ;Disable EALLOW protected register access
LB _c_int00 ;Branch to start of boot.asm in RTS library
.endif
;end wd_disable
.end
;// End of file.
