社区导航
搜索
查看: 589|回复: 10
[求助] 串口接收9600可以,但115200就丢字节是怎么回事?
TA的帖子
Rank: 1
发表于 2018-12-20 15:01:17 | 显示全部楼层 |阅读模式
MSP430FR6972,时钟用DCO,  8MHZ,串口接收在9600时可以,但115200就丢字节是怎么回事?
示波器看串口信号时间精度并无大的偏差。
void Init_Clock(void)
    // Startup clock system with max DCO setting ~8MHz
  CSCTL0_H = CSKEY >> 8;                    // Unlock clock registers
  CSCTL1 = DCOFSEL_3 | DCORSEL;             // Set DCO to 8MHz
  CSCTL2 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK;
  CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1;     // Set all dividers
  do
      CSCTL5 &= ~LFXTOFFG;                    // Clear XT1 fault flag
      SFRIFG1 &= ~OFIFG;                      // Clear oscillator fault flag
    }while (SFRIFG1&OFIFG);                  // Test oscillator fault flag
  CSCTL0_H = 0;                             // Lock CS registers
//     Configure USCI_A0 for UART mode
void Init_eUCA0 (void)
  UCA0CTLW0 = UCSWRST;                      // Put eUSCI in reset
  UCA0CTLW0 |= UCSSEL__SMCLK;               // CLK = SMCLK
  UCA1BR0 = 4;                             // 115200
  UCA1BR1 = 0x00;
  UCA1MCTLW |= UCOS16 | UCBRF_5 | 0x5500;
  UCA0CTLW0 &= ~UCSWRST;                    // Initialize eUSCI
  UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  UCA0IE |= UCTXCPTIE;                      // UART Transmit Complete Interrupt Enable
//    eUSCI_A0 interrupt service routine
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_A0_VECTOR))) USCI_A0_ISR (void)
#else
#error Compiler not supported!
#endif
  unsigned char uc_1;
  switch(__even_in_range(UCA0IV, USCI_UART_UCTXCPTIFG))
    case USCI_NONE:
          break;
    case USCI_UART_UCRXIFG:                    // UCAxRXBUF has received a complete character.
          uc_1 = UCA0RXBUF;
          S1_RXD_Buf[P_S1_R++] = uc_1;           //收到就送缓存
          break;
    case USCI_UART_UCTXIFG:     //UCAxTXBUF empty
          if(P_S1_T<P_S1_T1)
                 UCA1TXBUF = S1_TXD_Buf[P_S1_T++];
          else
                 B_S1_Busy = 0;                //清除发送忙标志
          break;
    case USCI_UART_UCSTTIFG:    //Start bit was received
          break;
    case USCI_UART_UCTXCPTIFG:  //UCAxTXBUF is empty
          if(P_S1_T<P_S1_T1)
                 while(!(UCA0IFG&UCTXIFG));
                 UCA0TXBUF = S1_TXD_Buf[P_S1_T++];
          else
          break;
使用道具 举报
TA的帖子
Rank: 1
 楼主| 发表于 2018-12-20 15:04:12 | 显示全部楼层
发送数据用串口调试工具看没问题。但接收从串口调试工具发来的数据,就会丢个别字节。
程序写的问题,不是硬件问题  详情 回复 发表于 2018-12-20 15:11
使用道具 举报
1061
TA的帖子
Rank: 6Rank: 6
发表于 2018-12-20 15:11:58 | 显示全部楼层
程序写的问题,不是硬件问题
使用道具 举报
721
TA的帖子
Rank: 5Rank: 5
发表于 2018-12-20 15:42:55 | 显示全部楼层
这个得看你的通信定义了,如果接收端就达不到这么高的接受速率,丢数据是多正常的事呀,所以看看你接收端的通讯定义,别在程序上浪费时间,因为这些都是很简单的东西,应该不会错的
使用道具 举报
TA的帖子
146
Rank: 6Rank: 6
技术导师勋章
发表于 2018-12-20 15:59:13 | 显示全部楼层
如果没有误码,说明是你的程序问题,接收相关程序的占用时间过长了。
如果同时有误码,说明硬件问题的可能性大,比如波特率误差、信噪比不足等。
上传了一些书籍资料,也许有你想要的:http://download.eeworld.com.cn/user/chunyang
使用道具 举报
TA的帖子
Rank: 1
发表于 2018-12-20 19:17:42 | 显示全部楼层
关注天津三格电子,使您走在时代的前段
三格电子产品宣传页.pdf
8.13 MB, 下载次数: 0
使用道具 举报
TA的帖子
Rank: 1
发表于 2018-12-20 21:48:18 | 显示全部楼层
  UCA1BR1 = 0x00;
这个配置没问题吗?
使用道具 举报
TA的帖子
Rank: 1
发表于 2018-12-21 09:03:24 | 显示全部楼层
图片3.png   关于modbus485 232 422 可关注天津三格电子科技有限公司,天津三格电子主做modbus485转光纤近十一年的时间,应用于许多工程,相信天津三格电子会给你一个满意的答复
使用道具 举报
678
TA的帖子
Rank: 3Rank: 3
发表于 2018-12-21 10:51:01 | 显示全部楼层
程序问题只能慢慢查啦,哎,不好弄的。
使用道具 举报
7141
TA的帖子
4933
博客管理员
Rank: 6Rank: 6
资源大师勋章
发表于 2018-12-21 16:33:52 | 显示全部楼层
看了你的寄存器配置,感觉配置正确。
8M时钟的话,115200的波特率也没啥问题。
丢的字节是一串数据的中间字节,还是最后的字节。除了丢字节,其他数据都正确吗
使用道具 举报
3625
TA的帖子
Rank: 9Rank: 9Rank: 9
发表于 2018-12-25 14:38:42 | 显示全部楼层
接收部分的处理,看看有没有耗时比较大的地方。丢数据。能不能找到规律。
使用道具 举报
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-1-20 16:56 , Processed in 0.307523 second(s), 17 queries , Gzip On, MemCache On.
