2129|9
6926
基于GD32F350的LED玩具 [复制链接]
LED玩具利用加速度传感器获取加速度,计算位置及加速度,将砂粒显示在LED显示屏上,砂砾随LED的角度流动、碰撞。
gd32_led_sand_toy.rar (9 MB, 下载次数: 632)
个人签名training
6926
   系统框图
LED_SAND_TOY.docx
2.38 MB, 下载次数: 486
个人签名training
1413
这创意不错,
这个主要用来发呆,想做成个魔方形式的,六面的,不过找不到合适的LED屏  详情 回复 发表于 2018-10-19 10:43
个人签名专注智能产品的研究与开发,专注于电子电路的生产与制造……QQ:2912615383,电子爱好者群: void
6926
个人签名training
6926
HUB75 RGB LED显示
下表为GB32HUB75接口32*16LED显示屏的连接;
HUB75接口中RGB为红黄蓝颜色数据线,ABC为线选, SCK为时钟,STR为锁存,OE为使能。
GD32 pin
PB14
PB0
PB4
PB2
HUB75接口定义
G1
GND
G2
GND
GND
STR
GND
R1
B1
R2
B2
SCK
OE
GD32 pin
PB13
PB15
PB12
PB1
PB5
PB3
PB10
PB11
LED显示屏为RGB全彩显示屏,分为上下亮屏,上半屏8行,下半屏8行,公用ABC三根线进行线选。
个人签名training
6926
1.  #include "gd32f3x0.h"
2.  #include "led75.h"
3.  #include "gd32f3x0_gpio.h"
4.  #include
5.  uint8_t frame[WIDTH * HEIGHT];
6.  void sda_r(unsigned int value)
7.  {
8.      gpio_bit_write(GPIOB, GPIO_PIN_13, (bit_status)value);
9.  }
10. void sda_g(unsigned int value)
11. {
12.     gpio_bit_write(GPIOB, GPIO_PIN_14, (bit_status)value);
13. }
14. void sda_b(unsigned int value)
15. {
16.     gpio_bit_write(GPIOB, GPIO_PIN_15, (bit_status)value);
17. }
18. void sda_rg(unsigned int value)
19. {
20.     gpio_bit_write(GPIOB, GPIO_PIN_13, (bit_status)value);
21.     gpio_bit_write(GPIOB, GPIO_PIN_14, (bit_status)value);
22. }
23. void sda_gb(unsigned int value)
24. {
25.     gpio_bit_write(GPIOB, GPIO_PIN_14, (bit_status)value);
26.     gpio_bit_write(GPIOB, GPIO_PIN_15, (bit_status)value);
27. }
28. void sda_rb(unsigned int value)
29. {
30.     gpio_bit_write(GPIOB, GPIO_PIN_13, (bit_status)value);
31.     gpio_bit_write(GPIOB, GPIO_PIN_15, (bit_status)value);
32. }
33. void sda_rgb(unsigned int value)
34. {
35.     gpio_bit_write(GPIOB, GPIO_PIN_13, (bit_status)value);
36.     gpio_bit_write(GPIOB, GPIO_PIN_14, (bit_status)value);
37.     gpio_bit_write(GPIOB, GPIO_PIN_15, (bit_status)value);
38. }
39. void sda_rs(unsigned int value)
40. {
41.     gpio_bit_write(GPIOB, GPIO_PIN_12, (bit_status)value);
42. }
43. void sda_gs(unsigned int value)
44. {
45.     gpio_bit_write(GPIOB, GPIO_PIN_0, (bit_status)value);
46. }
47. void sda_bs(unsigned int value)
48. {
49.     gpio_bit_write(GPIOB, GPIO_PIN_1, (bit_status)value);
50. }
51. void sda_rgs(unsigned int value)
52. {
53.     gpio_bit_write(GPIOB, GPIO_PIN_12, (bit_status)value);
54.     gpio_bit_write(GPIOB, GPIO_PIN_0, (bit_status)value);
55. }
56. void sda_gbs(unsigned int value)
57. {
58.     gpio_bit_write(GPIOB, GPIO_PIN_0, (bit_status)value);
59.     gpio_bit_write(GPIOB, GPIO_PIN_1, (bit_status)value);
60. }
61. void sda_rbs(unsigned int value)
62. {
63.     gpio_bit_write(GPIOB, GPIO_PIN_12, (bit_status)value);
64.     gpio_bit_write(GPIOB, GPIO_PIN_1, (bit_status)value);
65. }
66. void sda_rgbs(unsigned int value)
67. {
68.     gpio_bit_write(GPIOB, GPIO_PIN_12, (bit_status)value);
69.     gpio_bit_write(GPIOB, GPIO_PIN_0, (bit_status)value);
70.     gpio_bit_write(GPIOB, GPIO_PIN_1, (bit_status)value);
71. }
72. color_select_t led1[7] = {sda_r, sda_g, sda_b, sda_rg, sda_gb, sda_rb, sda_rgb};
73. color_select_t led2[7] = {sda_rs, sda_gs, sda_bs, sda_rgs, sda_gbs, sda_rbs, sda_rgbs};
74. void (*led1_send_data)(unsigned int);
75. void (*led2_send_data)(unsigned int);
76. void shcp_set(void)
77. {
78.     gpio_bit_set(GPIOB, GPIO_PIN_10);
79. }
80. void shcp_clear(void)
81. {
82.     gpio_bit_reset(GPIOB, GPIO_PIN_10);
83. }
84. void stcp_set(void)
85. {
86.     gpio_bit_set(GPIOB, GPIO_PIN_2);
87. }
88. void stcp_clear(void)
89. {
90.     gpio_bit_reset(GPIOB, GPIO_PIN_2);
91. }
92. void oe_set(void)
93. {
94.     gpio_bit_set(GPIOB, GPIO_PIN_11);
95. }
96. void oe_clear(void)
97. {
98.     gpio_bit_reset(GPIOB, GPIO_PIN_11);
99. }
100. void led75_abc_control(unsigned int abc, unsigned int on_off)
101. {
102.     switch(abc)
103.     {
104.         case LED75_A:
105.             gpio_bit_write(LED75_A_PORT, LED75_A_PIN, (bit_status)on_off);
106.             break;
107.         case LED75_B:
108.             gpio_bit_write(LED75_B_PORT, LED75_B_PIN, (bit_status)on_off);
109.             break;
110.         case LED75_C:
111.             gpio_bit_write(LED75_C_PORT, LED75_C_PIN, (bit_status)on_off);
112.             break;
113.         default:
114.             //assert(0);
115.             break;
116.     }
117. }
118. void line_scan(unsigned int line)
119. {
120.     switch(line)
121.     {
122.         case 0:
123.             led75_abc_control(LED75_A, 0);
124.             led75_abc_control(LED75_B, 0);
125.             led75_abc_control(LED75_C, 0);
126.             break;
127.         case 1:
128.             led75_abc_control(LED75_A, 1);
129.             led75_abc_control(LED75_B, 0);
130.             led75_abc_control(LED75_C, 0);
131.             break;
132.         case 2:
133.             led75_abc_control(LED75_A, 0);
134.             led75_abc_control(LED75_B, 1);
135.             led75_abc_control(LED75_C, 0);
136.             break;
137.         case 3:
138.             led75_abc_control(LED75_A, 1);
139.             led75_abc_control(LED75_B, 1);
140.             led75_abc_control(LED75_C, 0);
141.             break;
142.         case 4:
143.             led75_abc_control(LED75_A, 0);
144.             led75_abc_control(LED75_B, 0);
145.             led75_abc_control(LED75_C, 1);
146.             break;
147.         case 5:
148.             led75_abc_control(LED75_A, 1);
149.             led75_abc_control(LED75_B, 0);
150.             led75_abc_control(LED75_C, 1);
151.             break;
152.         case 6:
153.             led75_abc_control(LED75_A, 0);
154.             led75_abc_control(LED75_B, 1);
155.             led75_abc_control(LED75_C, 1);
156.             break;
157.         case 7:
158.             led75_abc_control(LED75_A, 1);
159.             led75_abc_control(LED75_B, 1);
160.             led75_abc_control(LED75_C, 1);
161.             break;
162.         default:
163.             break;
164.     }
165. }
166. void led_delay(unsigned int cnt)
167. {
168.     volatile unsigned int i;
169.     for(i=0; i
170.     {
171.         __NOP;
172.     }
173. }
174. void led_matrix_display(void)
175. {
176.     unsigned int i, j;
177.     unsigned int color;
178.     oe_set();
179.     /* 8 line per led */
180.     for(i=0; i<8; i++)
181.     {
182.         color = i;
183.         led1_send_data = led1[color].proc;
184.         led2_send_data = led2[color].proc;
185.         sda_rgb(0);
186.         sda_rgbs(0);
187.         for(j=0; j
188.         {
189.             shcp_clear();
190.             (*led1_send_data)(frame[i * WIDTH + j]);
191.             (*led2_send_data)(frame[(i + 8) * WIDTH + j]);
192.             shcp_set();
193.         }
194.         line_scan(i);
195.         stcp_clear();
196.         stcp_set();
197.         oe_clear();
198.         //delay_us(100);
199.         led_delay(0x2ff);
200.         oe_set();
201.     }
202. }
个人签名training
6926
MPU6050内部整合了3轴陀螺仪和3轴加速度传感器,通过IIC接口与GD32通信,通信速率400Khz。该设计中使用GD32F350IIC0,即PB6 SCL,PB7SDA
file:///C:/Users/gt/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg
MPU6050固定到LED显示屏上file:///C:/Users/gt/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg
MPU6050驱动代码如下:
2.  #include "mpu6050.h"
3.  #include
4.
5.  mpu6050_accel_t mpu6050_accel;
6.  mpu6050_gyro_t  mpu6050_gyro;
7.
8.  void mpu6050_write_1byte(unsigned char reg_addr, unsigned char data)
9.  {
10.     while(i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_I2CBSY));
11.     i2c_start_on_bus(MPU6050_IIC_DEV);
12.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_SBSEND));
13.     i2c_master_addressing(MPU6050_IIC_DEV, SLAVE_ADDRESS, I2C_TRANSMITTER);
14.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND));
15.     i2c_flag_clear(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND);
16.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_TBE));
17.     i2c_data_transmit(MPU6050_IIC_DEV, reg_addr);
18.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_BTC));
19.     i2c_data_transmit(MPU6050_IIC_DEV, data);
20.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_BTC));
21.     i2c_stop_on_bus(MPU6050_IIC_DEV);
22.     while(I2C_CTL0(MPU6050_IIC_DEV)&0x0200);
23. }
24.
25. unsigned char mpu6050_read_1byte(unsigned char reg_addr)
26. {
27.     unsigned char   data;
28.     while(i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_I2CBSY));
29.     i2c_start_on_bus(MPU6050_IIC_DEV);
30.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_SBSEND));
31.     i2c_master_addressing(MPU6050_IIC_DEV, SLAVE_ADDRESS, I2C_TRANSMITTER);
32.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND));
33.     i2c_flag_clear(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND);
34.     i2c_data_transmit(MPU6050_IIC_DEV, reg_addr);
35.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_BTC));
36.     i2c_start_on_bus(MPU6050_IIC_DEV);
37.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_SBSEND));
38.     i2c_master_addressing(MPU6050_IIC_DEV, SLAVE_ADDRESS, I2C_RECEIVER);
39.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND));
40.     i2c_flag_clear(MPU6050_IIC_DEV, I2C_FLAG_ADDSEND);
41.
42.     i2c_ack_config(MPU6050_IIC_DEV, I2C_ACK_DISABLE);
43.     while(!i2c_flag_get(MPU6050_IIC_DEV, I2C_FLAG_RBNE));
44.     data = i2c_data_receive(MPU6050_IIC_DEV);
45.     i2c_stop_on_bus(MPU6050_IIC_DEV);
46.     while(I2C_CTL0(MPU6050_IIC_DEV)&0x0200);
47.     i2c_ack_config(MPU6050_IIC_DEV, I2C_ACK_DISABLE);
48.
49.     return data;
50. }
51.
52. void mpu6050_accel_read(void)
53. {
54.     uint8_t h, l;
55.     h = mpu6050_read_1byte(ACCEL_XOUT_H);
56.     l = mpu6050_read_1byte(ACCEL_XOUT_L);
57.     mpu6050_accel.x = (int16_t)((h << 8) | l);
58.     h = mpu6050_read_1byte(ACCEL_YOUT_H);
59.     l = mpu6050_read_1byte(ACCEL_YOUT_L);
60.     mpu6050_accel.y = (int16_t)((h << 8) | l);
61.     h = mpu6050_read_1byte(ACCEL_ZOUT_H);
62.     l = mpu6050_read_1byte(ACCEL_ZOUT_L);
63.     mpu6050_accel.z = (int16_t)((h << 8) | l);
64. }
65. void mpu6050_gypo_read(void)
66. {
67.     uint8_t h, l;
68.     h = mpu6050_read_1byte(GYRO_XOUT_H);
69.     l = mpu6050_read_1byte(GYRO_XOUT_L);
70.     mpu6050_gyro.x = (int16_t)((h << 8) | l);
71.     h = mpu6050_read_1byte(GYRO_YOUT_H);
72.     l = mpu6050_read_1byte(GYRO_YOUT_L);
73.     mpu6050_gyro.y = (int16_t)((h << 8) | l);
74.     h = mpu6050_read_1byte(GYRO_ZOUT_H);
75.     l = mpu6050_read_1byte(GYRO_ZOUT_L);
76.     mpu6050_gyro.z = (int16_t)((h << 8) | l);
77. }
78.
79. void mpu6050_init(void)
80. {
81.     mpu6050_write_1byte(PWR_MGMT_1, 0x00);
82.     mpu6050_write_1byte(SMPLRT_DIV, 0x7);
83.     mpu6050_write_1byte(CONFIG, 0x06);
84.     mpu6050_write_1byte(GYRO_CONFIG, 0x18);
85.     mpu6050_write_1byte(ACCEL_CONFIG, 0x09); ////+-4g
86. }
个人签名training
6926
将三维加速度转换为二维加速度,计算每个砂粒加速度。
1.  void calc_accel(void)
2.  {
3.      unsigned int i;
4.      int ax, ay, az;
5.      int az2;
6.      int32_t v2;
7.      float v;
8.
9.      ax = -mpu6050_accel.y / 256;
10.     ay = -mpu6050_accel.x / 256;
11.     az = abs(mpu6050_accel.z) / 2048;
12.     az = (az >= 3) ? 1 : (4 - az);
13.     ax -= az;
14.     ay -= az;
15.     az2 = az * 2 + 1;
16.
17.     for(i=0; i
18.     {
19.         grain.vx += ax + rand_s(az2);
20.         grain.vy += ay + rand_s(az2);
21.         v2 = (int32_t)(grain.vx * grain.vx) + (int32_t)(grain.vy * grain.vy);
22.         if(v2 > 65536)
23.         {
24.             v = sqrt((float)v2);
25.             grain.vx = (int)(256.0 * (float)grain.vx / v);
26.             grain.vy = (int)(256.0 * (float)grain.vy / v);
27.         }
28.     }
29. }
计算砂砾位置写入显存数据帧;
1.  void calc_pos(void)
2.  {
3.      unsigned int i;
4.      unsigned int oldidx, newidx, delta;
5.      int newx, newy;
6.
7.      for(i=0; i
8.      {
9.          newx = grain.x + grain.vx;
10.         newy = grain.y + grain.vy;
11.
12.         if(newx > MAX_X)
13.         {
14.             newx = MAX_X;
15.             grain.vx /= -2;
16.         }
17.         else if(newx < 0)
18.         {
19.             newx = 0;
20.             grain.vx /= -2;
21.         }
22.         if(newy > MAX_Y)
23.         {
24.             newy         = MAX_Y;
25.             grain.vy /= -2;
26.         }
27.         else if(newy < 0)
28.         {
29.             newy         = 0;
30.             grain.vy /= -2;
31.         }
32.         oldidx = (grain.y/256) * WIDTH + (grain.x/256); // Prior pixel #
33.         newidx = (newy      /256) * WIDTH + (newx      /256); // New pixel #
34.
35.         /* the newidx has grain */
36.         if((oldidx != newidx) && frame[newidx])
37.         {
38.             delta = abs(newidx - oldidx);
39.             /* left or right has a grain */
40.             if(1 == delta)
41.             {
42.                 newx = grain.x;
43.                 grain.vx /= -2;
44.                 newidx= oldidx;
45.             }
46.             /* up or down has a grain */
47.             else if(WIDTH == delta)
48.             {
49.                 newy = grain.y;
50.                 grain.vy /= -2;
51.                 newidx = oldidx;
52.             }
53.             else
54.             {
55.                 /* x axis is faster */
56.                 if((abs(grain.vx) - abs(grain.vy)) >= 0)
57.                 {
58.                     newidx = (grain.y / 256) * WIDTH + (newx / 256);
59.                     if(!frame[newidx])
60.                     {
61.                         newy = grain.y;
62.                         grain.vy /= -2;
63.                     }
64.                     else
65.                     {
66.                         newidx = (newy / 256) * WIDTH + (grain.x / 256);
67.                         if(!frame[newidx])
68.                         {
69.                             newx = grain.x;
70.                             grain.vx /= -2;
71.                         }
72.                         else
73.                         {
74.                             newx = grain.x;
75.                             newy = grain.y;
76.                             grain.vx /= -2;
77.                             grain.vy /= -2;
78.                             newidx = oldidx;
79.                         }
80.                     }
81.                 }
82.                 else //y axis is faster
83.                 {
84.                     newidx = (newy / 256) * WIDTH + (grain.x / 256);
85.                     if(!frame[newidx])
86.                     {
87.                         newx = grain.x;
88.                         grain.vy /= -2;
89.                     }
90.                     else
91.                     {
92.                         newidx = (grain.y / 256) * WIDTH + (newx / 256);
93.                         if(!frame[newidx])
94.                         {
95.                             newy = grain.y;
96.                             grain.vy /= -2;
97.                         }
98.                         else
99.                         {
100.                             newx = grain.x;
101.                             newy = grain.y;
102.                             grain.vx /= -2;
103.                             grain.vy /= -2;
104.                             newidx = oldidx;
105.                         }
106.                     }
107.                 }
108.             }
109.         }
110.         grain.x = newx;
111.         grain.y = newy;
112.         frame[oldidx] = 0;
113.         frame[newidx] = 1;
114.     }
115. }
个人签名training
6926
1.     使用的GD32F350外设
Ø  USART
USART初始化
Ø  rcu_periph_clock_enable(RCU_GPIOA);
Ø     rcu_periph_clock_enable(RCU_USART1);
Ø
Ø     /* connect port to USART1_Tx */
Ø     gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_2);
Ø
Ø     /* connect port to USART1_Rx */
Ø     gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_3);
Ø
Ø     /* configure USART1 Tx as alternate function push-pull */
Ø     gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_2);
Ø     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_2);
Ø
Ø     /* configure USART2 Rx as alternate function push-pull */
Ø     gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_3);
Ø     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_3);
Ø
Ø     /* USART1 configure */
Ø     usart_deinit(USART1);
Ø     usart_baudrate_set(USART1,115200);
Ø     usart_receive_config(USART1, USART_RECEIVE_ENABLE);
Ø     usart_transmit_config(USART1, USART_TRANSMIT_ENABLE);
Ø     usart_enable(USART1);
Ø  Iic
I2C初始化
1.  /* init iic0 for mpu6050 */
2.  rcu_periph_clock_enable(RCU_GPIOB);
3.  rcu_periph_clock_enable(RCU_I2C0);
4.  /* connect port to I2C0 SCL */
5.  gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_6);
6.  /* connect port to I2C0 SDA */
7.  gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_7);
8.  gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_6);
9.  gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
10. o_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
11. gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
12.
13. i2c_deinit(I2C0);
14. i2c_clock_config(I2C0, 400000, I2C_DTCY_2);
15. i2c_mode_addr_config(I2C0, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, 0x0A);
16. i2c_enable(I2C0);
17. i2c_ack_config(I2C0, I2C_ACK_DISABLE);
Ø  GPIO
GPIO初始化
Ø     /* init led display gpio */
Ø  //rcu_periph_clock_enable(RCU_GPIOB);
Ø  /*r g b*/
Ø     gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE,
Ø                   GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15);
Ø  gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_2MHZ,
Ø  /*rs gs bs*/
Ø                   GPIO_PIN_12|GPIO_PIN_0|GPIO_PIN_1);
Ø  /*ABC*/
Ø                   GPIO_PIN_5|GPIO_PIN_4|GPIO_PIN_3);
Ø     /*OE*/
Ø                   GPIO_PIN_11);
Ø                             GPIO_PIN_11);
Ø  /*SCK*/
Ø                   GPIO_PIN_10);
Ø                             GPIO_PIN_10);
Ø  /*STR*/
Ø                   GPIO_PIN_2);
Ø                             GPIO_PIN_2);
个人签名training
6926
演示视频地址http://training.eeworld.com.cn/video/16136
个人签名training
