社区导航
搜索
查看: 2953|回复: 0
[经验] Ubuntu安装OpenCV
3656
TA的帖子
Rank: 9Rank: 9Rank: 9
发表于 2018-10-9 20:12 | 显示全部楼层 |阅读模式
Ubuntu16.04     OpenCV3.2.0
安装opencv依赖包
sudo apt-get install build-essential
sudo apt-get install cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-devsudo apt-get install python-dev python-numpy libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-devsudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev liblapacke-devsudo apt-get install libxvidcore-dev libx264-dev sudo apt-get install libatlas-base-dev gfortran  sudo apt-get install ffmpeg
下载opencv
wget https://github.com/opencv/opencv_contrib/archive/3.2.0.zip网速太慢的话,可以用下载器试试。 解压得到opencv-3.2.0cd opencv-3.2.0mkdir buildcd buildcmake -D CMAKE_BUILD_TYPE=Release -D CMAKE_INSTALL_PREFIX=/usr/local ..makesudo make install添加库路径 vi  /etc/ld.so.conf.d/opencv.conf输入/usr/local/lib  保存环境变量
vi  /etc/profile
在末尾加入:
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:$PKG_CONFIG_PATH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
source  /etc/profile
vi  /etc/bash.bashrc
在末尾加入:
export PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig
source  /etc/bash.bashrc
sudo ldconfig
查看版本信息。检查是否安装成功。pkg-config   --modversion opencv
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2019-6-25 20:22 , Processed in 0.078845 second(s), 18 queries , Gzip On, MemCache On.
