An FPGA Design Security Solution Using a Secure Memory Device[复制链接]
Introduction
FPGA designs are vulnerable to design theft because configuration bitstreams can be easily captured and copied.
FPGAs are more vulnerable to cloning of the entire design rather than to intellectual property (IP) theft, since
extracting IP from the bitstream is nearly impossible. In order to protect the configuration bitstream, some FPGAs are
now capable of encrypting the bitstream. However, there is an additional cost for FPGAs that do not offer embedded
bitstream encryption to encrypt the configuration bitstream due to the additional step of programming the encryption
key in the FPGA during manufacturing. For high-volume applications, using a security companion chip is much more
cost effective.
This document provides a solution to help protect FPGA designs from being cloned. Using the “identification, friend
or foe” (IFF) design security approach, this solution disables the design within the FPGA until the hash algorithm
computation matches in both the FPGA and a secure memory device, so the design remains secure even if the
configuration data bitstream is captured. In this solution, the secure memory device is use as a security companion
chip for the FPGA.
