5730|0
1379
裸片初长成(中级)
51 IO口模拟串口通讯C源程序 [复制链接]
8){fontsize_6562.style.fontSize=(--curfontsize_6562)+"pt";fontsize_6562.style.lineHeight=(--curlineheight_6562)+"pt";}'>减小字体 增大字体
#include <reg51.h>
sbit BT_SND =P1^0;
sbit BT_REC =P1^1;
IO 口模拟232通讯程序
使用两种方式的C程序 占用定时器0
#define MODE_QUICK
#define F_TM F0
#define TIMER0_ENABLE  TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
sbit ACC0=   ACC^0;
sbit ACC1=   ACC^1;
sbit ACC2=   ACC^2;
sbit ACC3=   ACC^3;
sbit ACC4=   ACC^4;
sbit ACC5=   ACC^5;
sbit ACC6=   ACC^6;
sbit ACC7=   ACC^7;
void IntTimer0() interrupt 1
F_TM=1;
//发送一个字符
void PSendChar(unsigned char inch)
#ifdef MODE_QUICK
ACC=inch;
F_TM=0;
BT_SND=0; //start bit
TIMER0_ENABLE; //启动
while(!F_TM);
BT_SND=ACC0; //先送出低位
F_TM=0;
while(!F_TM);
BT_SND=ACC1;
F_TM=0;
while(!F_TM);
BT_SND=ACC2;
F_TM=0;
while(!F_TM);
BT_SND=ACC3;
F_TM=0;
while(!F_TM);
BT_SND=ACC4;
F_TM=0;
while(!F_TM);
BT_SND=ACC5;
F_TM=0;
while(!F_TM);
BT_SND=ACC6;
F_TM=0;
while(!F_TM);
BT_SND=ACC7;
F_TM=0;
while(!F_TM);
BT_SND=1;
F_TM=0;
while(!F_TM);
TIMER0_DISABLE; //停止timer
#else
unsigned char ii;
ii=0;
F_TM=0;
TIMER0_ENABLE; //启动
while(!F_TM);
while(ii<8)
if(inch&1)
BT_SND=1;
else
BT_SND=0;
F_TM=0;
while(!F_TM);
ii++;
inch>>=1;
BT_SND=1;
F_TM=0;
while(!F_TM);
#endif
//接收一个字符
unsigned char PGetChar()
#ifdef MODE_QUICK
TIMER0_ENABLE;
F_TM=0;
while(!F_TM); //等过起始位
ACC0=BT_REC;
TL0=TH0;
F_TM=0;
while(!F_TM);
ACC1=BT_REC;
F_TM=0;
while(!F_TM);
ACC2=BT_REC;
F_TM=0;
while(!F_TM);
ACC3=BT_REC;
F_TM=0;
while(!F_TM);
ACC4=BT_REC;
F_TM=0;
while(!F_TM);
ACC5=BT_REC;
F_TM=0;
while(!F_TM);
ACC6=BT_REC;
F_TM=0;
while(!F_TM);
ACC7=BT_REC;
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return ACC;
#else
unsigned char rch,ii;
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
rch>>=1;
if(BT_REC)
rch|=0x80;
ii++;
F_TM=0;
while(!F_TM);
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return rch;
#endif
//检查是不是有起始位
bit StartBitOn()
return  (BT_REC==0);
void main()
unsigned char gch;
TMOD=0x22; /*定时器1为工作模式2(8位自动重装),0为模式2(8位
自动重装) */
PCON=00;
TR0=0; //在发送或接收才开始使用
TF0=0;
TH0=(256-96); //9600bps 就是 1000000/9600=104.167微秒 执行的
timer是
104.167*11.0592/12= 96
TL0=TH0;
ET0=1;
EA=1;
PSendChar(0x55);
PSendChar(0xaa);
PSendChar(0x00);
PSendChar(0xff);
while(1)
if(StartBitOn())
gch=PGetChar();
PSendChar(gch);
此帖出自51单片机论坛
【直播时间】5月28日(周三)上午10:00
