社区导航
搜索
查看: 7958|回复: 10
[讨论] Simple socket server 例程 的调试问题
8910
TA的帖子
Rank: 9Rank: 9Rank: 9
发表于 2010-4-6 13:57 | 显示全部楼层 |阅读模式
最近在用Cyclone III FPGA Development Kit 这个板子在调Simple Socket Sever这个例程,但是好多天了一直不能调通,网线没有问题,IP设置也没有问题,程序运行显示初始化也成功了,但是一直ping 不通 。希望有经验的朋友能给予一些指点,先谢谢了!!
     下面是程序运行的过程:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
=============== Software License Reminder ================
This software project uses an unlicensed version of the NicheStack TCP/IP
Network Stack - Nios II Edition. If you want to ship resulting object
code in your product, you must purchase a license for this software from
Altera. For information go to: "http://www.altera.com/nichestack"
InterNiche Portable TCP/IP, v3.0
Copyright 1996-2003 by InterNiche Technologies. All rights reserved.
prep_tse_mac
Your Ethernet MAC address is 00:07:ed:ff:8f:11
Static IP Address is 192.168.1.2
prepared 1 interface, initializing...
[tse_mac_init]
SGDMA desc memory cleared
[phyID] 0x12 141 cc2
[netif_tse] found Marvell 88E1111 PHY
[triple_speed_ethernet_init] Speed is 1000 is 1  Full Duplex is 1
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
IP address of et1 : 192.168.1.2
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
此帖出自FPGA/CPLD论坛
22
TA的帖子
Rank: 4
发表于 2010-10-18 21:06 | 显示全部楼层
求助
我的也是出现了同样的问题,请问您是怎么解决的呀,很愁人,我的qq是369417794,邮件zhlei06@163.com,希望能得到您的帮助
使用道具 举报
TA的帖子
Rank: 1
发表于 2014-9-12 16:31 | 显示全部楼层
您好,我现在遇到跟您一样的问题(开发环境也是一样的),如能指教一下不胜感激!!!我的qq是429497396,邮件mjoly226@126.com,希望能得到您的帮助
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-5-26 19:19 | 显示全部楼层
我来结个帖。
In the Simple Socket Server, it uses GMII mode interface which we have to modify in the ins_tse_mac.c code。
Around line 327, the code “marvell_cfg_gmii(tse[iface].mi.base);” is included in order for the Simple Socket Server to operate in GMII mode.
因此,把ins_tse_mac.c里面327行加上marvell_cfg_gmii(tse[iface].mi.base);这句话就行了
使用道具 举报
TA的帖子
Rank: 1
发表于 2015-5-26 19:20 | 显示全部楼层
以下是正确的运行结果:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:12:34:56
prepped 1 interface, initializing...
[tse_mac_init]
INFO    : TSE MAC 0 found at address 0x06002000
INFO    : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0]
INFO    : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO    : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO    : PHY[0.0] - Auto-Negotiation PASSED
INFO    : PHY[0.0] - Checking link...
INFO    : PHY[0.0] - Link established
INFO    : PHY[0.0] - Speed = 1000, Duplex = Full
MARVELL : Mode changed to GMII to copper mode
MARVELL : Disable RGMII Timing Control
MARVELL : PHY reset
mctest init called
IP address of et1 : 192.168.1.234
DHCP timed out, going back to default IP address(es)
老大,我出来的界面跟你发的一模一样,可是就ping不同,请你多指教啊,要哭了!!  详情 回复 发表于 2016-12-27 13:43
使用道具 举报
58
TA的帖子
Rank: 1
发表于 2016-11-10 14:10 | 显示全部楼层
[img]file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\369456627\QQ\WinTemp\RichOle\Q)%}3E8(SV(LZ6[(H_O~K[O.png[/img]
使用道具 举报
58
TA的帖子
Rank: 1
发表于 2016-11-10 14:11 | 显示全部楼层
nios ii 已经显示上面的内容,但是ping 不通过,是为什么? 求大神帮助。
使用道具 举报
45
TA的帖子
Rank: 2
发表于 2016-12-27 13:43 | 显示全部楼层
ing016 发表于 2015-5-26 19:20
以下是正确的运行结果:
Copyright 1996-2008 by InterNiche Techn ...
使用道具 举报
137
TA的帖子
Rank: 2
发表于 2018-3-18 01:03 | 显示全部楼层
我也遇到这个问题了,待解
使用道具 举报
137
TA的帖子
Rank: 2
发表于 2018-3-20 22:55 | 显示全部楼层
我也遇到同样的问题
使用道具 举报
137
TA的帖子
Rank: 2
发表于 2018-3-20 22:57 | 显示全部楼层
我也遇到这个问题了,待解。开发板的FAQ就不能给个说法吗?
使用道具 举报
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-6-1 07:02 , Processed in 0.345247 second(s), 32 queries , Gzip On, MemCache On.
